Price: $199.99 - $119.99
(as of Apr 15, 2025 14:30:30 UTC – Details)
Portable Power Station 300W, GRECELL 288Wh Solar Generator with 60W USB-C PD Output, 110V Pure Sine Wave AC Outlet Backup Lithium Battery for Outdoors Camping Travel Hunting Home Blackout (600W Surge)
【Upgraded Battery Management System】We promise to adopt quality lithium batteries since we found that the use of lower-quality batteries could pose a serious risk to life and should become a crucial part of deciding what to buy. Upgraded BMS provides built-in overload, overcharge (automatically stops charging when the device is full), and short-circuit protection. Dual built-in silent cooling fans help to keep the station’s temperature safe.
【USB-C PD 60W, USB-A QC 18W】PD60W fast charging makes it possible to charge Android and iPhone, tablets, and laptops quickly, more than twice as fast as other standard USB-C output, and ultra-high efficiency in emergencies. All USB-A ports are quick-charge 3.0 18W, providing higher efficiency for each device.
【Power 8 Device simultaneously】Equipped with 1*AC output, 1*USB-C PD 60W output, 3*USB-A QC3.0 18W outputs, 1*Car port, 2*DC outputs, GRECELL solar generator can power eight devices at the same time (as long as they draw less than 330W combined). Each switch can control each output module.
【3 Ways To Recharge, Built-in MPPT Controller】GRECELL power station, can be charged via an AC outlet, a solar panel, or a car outlet. Built-in MPPT (Maximum Power Point Tracking Control) so it can extract the maximum power from the solar panel, optimizing the utilization of variable power sources like a solar generator.
