Portable Power Station 1228Wh/1500W, VDL HS1500 LiFePO4 Solar Generator Fully Charged 2 Hours, 6x110V Pure Sinewave AC Outlets Backup Battery Power Supply for Home Use Outdoor Camping RV Emergency
Price: $2,299.00 - $359.00
(as of Mar 28, 2025 07:15:22 UTC – Details)
Wattage :
1500 watts
🔋【Pure Sine Wave AC 1500W】Solar Generator(Solar Panel Optional) has 6 pure sine wave AC outlets with 1500W output (2000W peak), so it can charge most of appliances, such as smartphones, computers, drones, cameras, heaters, air conditioners, rice cookers, microwaves, hair dryers, TVs, refrigerators, electric blankets and home dryers. The reliable AC pure sine wave output protects your appliances from damage.
🔋【Power up to 15 devices at the same time】4 x 18W USB Type-A QC3.0, 2 x 100W USB Type-C, 1 x 108.8W cigarette outlet output, 2 x 108.8W DC output, 6 x AC 1500W output (110V/60 Hz). Up to 15 devices can be powered at the same time (total power not exceeding 1500W).
🔋【3500 charge/discharge cycles, four charging methods】AC fast charge, car socket, generator and solar panel, so you can charge your portable power wherever you are. Using automotive power grade rechargeable lithium iron phosphate battery, which has more than 3500 charge/discharge cycles, the VDL portable power supply has a longer service life compared to other products with 500-800 cycles.
🔋【High safety, BMS intelligent protection system】This product has been certified by PSE, FCC, MSDS, RoHS and UN 38.3. Equipped with BMS (Battery Management System) to ensure high safety through output overcurrent protection, input/output overvoltage protection, output undervoltage protection, overheat protection and short circuit protection. It is also equipped with MPPT system (Maximum Power Point Tracking) to ensure that the solar panel charges the power source with maximum efficiency.
🔋【LIFETIME TECHNICAL SUPPORT】 VDL provides 5 years warranty and lifetime technical support. If you have any questions, please feel free to contact us. What’s Included: 1 * HS1500 (1228Wh/1500W) Portable Power Station, 1* AC Power Cord, 1* Car Charging Cable, 1 * XT60 to MC4 Adapter Cable,1* User Manual
