Portable 4G LTE Mobile WiFi Hotspot with SIM Card Slot, RJ45 WAN LAN 300Mbps, Supports 32 Users, for Travel Indoor Outdoor
Price: $47.58
(as of – Details)
Specification:
Item Type: 4G LTE Mobile Wifi Hotspot
Material: ABS
Size: Approx. 105 x 60 x 18mm / 4.1 x 2.36 x 0.7in
Battery: Lithium Ion Battery (Ship with Inbuilt Battery)
Capacity: 2600 mAh
Interface Type:
1xRJ45 Interface (WAN/LAN Adaptive)
1xmicro USB Port
1xPower Button
1xWPS button
Card Slot:
1xMicro SIM Card Slot, 1xMemory Card slot (without SIM Card and Memory Card, Supports up to 32GB Memory Card)
SIM Card Band:
LTE FDD: B1/B2/B3/B4/B5/B7/B8/B17/B20/B28.
LTE TDD: B38/B39/B40/B41
HSPA+/HSPA/UMTS: B1/ B2/B5/ B9
GSM: 850MHz/900MHz/1800MHz/1900MHz
Transmission Rate: 300Mbps
Firewall Function: Support Firewall
WIFI: Support 802.11 b/g/n (Support 802.11 b/g/n)
How to Use:
Take out the product and use it
Package List:
1 x Router
1 x Battery
1 x USB Cable
Notice:
Actual battery life may vary depending on usage environment
[SIMPLE SETUP] – Just insert the 4G card into the SIM card slot to start using this wireless router. It’s easy to set up and use.
[SUPPORTS 32 USERS] – Perfect for car users, business travelers, and outdoor adventurers, this mobile WiFi hotspot supports up to 32 users at the same time, allowing multiple devices to connect.
[VERSATILE CONNECTIVITY] – Connect your cell phones and computers to the internet with the WiFi hotspot feature or use the RJ45 port for a wired connection. Stay connected wherever you go.
[LONG BATTERY LIFE] – With a 2600mAh rechargeable battery, this mobile WiFi hotspot has a low power consumption and provides up to 10 hours of working time and 300 hours of standby time.
