Nuoenx Wireless Backup Camera, 9 Inch HD 1080P Loop Recording Monitor with 2 Rear View Camera System for Cars, Trucks, RV, Trailers, IP69K Waterproof 152° View Camera, Stable Wireless Signal (W902)
Price: $219.99 - $109.98
(as of Mar 28, 2025 14:45:22 UTC – Details)
Backup CameraBackup Camera
Start your safe and ease journey with Nuoenx upgrade quad wireless backup camera system!
Upgrade Quad RV Backup Camera Wireless with Monitor – This system includes a 9 inch monitor with recording function and two wireless backup camera rv. Warmly tips: If you want to add the other 2 cameras, please contact Nuoenx through Amazon message to purchase separately.
Special Design for RV/Trailer/Truck – The monitor supports full screen display and split screen with 2/3/4 channels. You could monitor the 4 camera at the same time, just press (AV) button and switch for CAM1 to CAM4.
Pre-paired Cameras – All the products will go through a strict inspection and the cameras are paired before shipping. If you have any question about the product or have pairing issue, please do not hesitate to tell us, we are ready to assist you!
Some questions you may care about…
Q1: Does this system need to be hard wired?
A: Yes, please noted that the wireless means we don’t need to connect the camera and monitor with cable, the signal transit through the antennas. But the camera and monitor need to be connencted to power supply separately.
Q2: What should I do if the system lost signal?
A: Please cut the power of the camera at first, then short press (MENU) button to choose the menu and find the “PAIRING” function, and then press (MODE) button to select and enter the pairing mode. There will shows “Pairing Start” and count down from 20 second on screen during pairing, please power the camera within this time. After that, the camera view appear and complete pairing.
Q3: Missing some parts in my package?
A: Do not hesitate to tell us through Amazon message or contact Nuoenx directly (you can find the email address on the user manual), we will send it to you as soon as possible.
Q4: I don’t like it/Doesn’t work as my expectation.
A: We offer 3 months replacement for all Nuoenx backup cameras, just feel free to tell us, we are ready to assist you!
9″ Monitor with Loop Recording
The monitor has built-in video recording function to record the driving video, making your driving more convenient and safe.
4 Camera Channels
This system supports up to 4 wireless backup cameras, you can choose to display CAM1 to CAM4 in single view / dual view / triple view / quad view.
Adjustable Guidelines
You could choose to turn on/off or adjust the parking guide lines according to your needs.
IP69K Waterproof Camera
With IP69K waterproof standard, the wireless backup camera rv can work in extreme weather from -4℉~176℉.
Easy Installation
Voltage Range: DC 12-24V, 1-2A
1. Power the screen:
Please plug into a cigarette lighter or power port and connect the wire to screen. There has a usb charger on the back of the plug so you can still plug a phone charger into it.
2. Power the camera:
(1) Connect to the running light or reverse light, the screen and camera will be on when you turn on the running light or reversing.
(2) Connect to the battery, the screen and camera will be on when you start the car.
BE ATTENTION!
The wireless means it don’t need to connect the camera and monitor with wires, the signal transit through the antennas. But the camera and monitor need to be connencted to the power supply separately.
Packing List 9 Inch Monitor x1 Backup Camera x2 SD Card x1 Bracket for Monitor x2 Power Cord x3 Antenna x4 Car Charger x1 Installation Kits x1
🚚🚚 1080P MULTIFUNCTIONAL MONITOR – The monitor has a built-in 32GB SD card to record driving videos. With 1080 screen resolution, supports up to 4 cameras in single view / dual view / triple view / quad view, make your driving safer! Monitor size: 9(W)*6(H) inch. Rear Camera size: 3.15(W)*3.35(H) inch.
🚚🚚 IP69K WATERPROOF BACKUP CAMERA – The high quality backup camera is suitable for all kinds of vehicles. Build with IP69K waterproof standard, durable in rainy days for more than 2 years. With wide view angle and high-resolution sensor ensure high-definition and smooth image quality! The highest and lowest temperature resistance is -4°F~176°F. Suitable voltage range is 12V-24V
🚚🚚 DIGITAL WIRELESS & EASY INSTALLATION – The backup camera system with digital wireless transmission makes the installation much easier. Just connenct the camera and monitor separately to power supply: (1) Power the monitor by the included cigarette lighter or Fuse box, ACC, Radio, Ignition switch. (2) Connect the camera to continuous power source like Tail light/Running light/license plate light for monitoring, or connect to backup light for reversing only
🚚🚚 LONG SIGNAL TRANSMISSION DISTANCE – The max wireless working range is over 300ft in open area ,and 50ft on vehicle for reversing or 36ft on vehicle for continuously use, which is long enough for most vehicles, like Cars, Trucks, Pickups, Camper, SUVs, Trailers, and Minivans.
