Price: $21.90 - $19.99
(as of Dec 12, 2024 19:00:43 UTC – Details)
Radio Band
NOAA+FM+AM NOAA+FM+AM NOAA+FM+AM FM+AM +MP3 NO NOAA+FM+AM
Support Weather alert
Power supply
2 AA Battery 1500MAH Battery; Charging Cable 1500MAH Battery; Charging Cable 2200MAH Battery; Charging Cable 4pcs battery 2 AA Battery
Support TF card
Support Flashlight
Features
digital alarm clock radio. Manual tuning and auto Scan Manual tuning,Large capacity battery, Powerfuf flashlight, HIFI sound Manual tuning,Large capacity battery, super flashlight, HIFI sound Large capacity battery, super flashlight, HIFI sound ,MP3 PLAYER battery protection case, rechargeable battery case, POWER BANK digital alarm clock radio. Manual tuning and auto Scan
Packing List
headphone,User manual, Charging Cable,User manual battery Charging Cable,User manual battery Charging Cable,User manual, battery Charging Cable headphone,User manual,
color
Black white blue blue black White
note
Our radio with AM/FM/ NOAA weather Alert radio.can automatically or manually get weather broadcasts from 7 NOAA stations at a crystal-clear sound. This weather radio can automatically monitor and alert hazard weathers in your area like hurricanes, tornadoes and sever storms, earns a critical time for you to get full preparation advance, keeping you and your family safe with this noaa radio. Small size:4.9*2.7*0.8 IN, convenient for you to carry or put in thee mergency bag.
when the battery is taken out, The time memory will belost in 30 seconds. Please install a new battery within 30 seconds. Please donot turn on the backlight when changing the battery.
The package does not contain batteries. Please purchase AA batteries separately
FM+AM+WB(Weather bad)
FM: 87-108MHZ
AM: 520-1710 KHz
NOAA Weather:162.400/ 162.425/ 162.450/ 162.475/ 162.50/ 162.525/ 162.55 (continuous band)
noaa auto alert
When there is an alarm signal, the radio will start and the screen backlight will flash and alarm
2 AA battery operated
Powered by 2 AA batteries, this noaa weather alert radio enables you to use for 2 weeks, even in power outage you still can receive weather information from this portable transistor radio, keep you update with lasted news.
3 shortcut keys
When you want to listen to your favorite radio station, you only need to press the shortcut keys to play your favorite radio station immediately. Simple operation, save you time.
Sleep Timer and Alarm Clock
This pocket radio has an automatic shutdown function. You can set the snooze function to turn it off after 30/60/90/120 minutes.
you can listen to radio programs at needed time through setting of alarm clock.
Listen with Earphone
plug the earphone(included) in the 3.5mm headphone jack on this noaa weather radio, a stereo sound will come in FM and give you more joy on it.Enjoy Personal Time
❤ AM/FM/Weather Band☛ using excellent integrated circuit, with high sensitivity and reception. It has two kinds of tuning models,automatic electronic tuning and manual tuning.With 4.9*2.7*0.8 IN little size, you can put the radio into your pocket, handbag, backpack or shopping bag easily. It is really a good choice for outdoor, travel, sports and indoor use
❤Preset buttons for Favorite Stations ☛You can set shortcuts for your favorite stations , When you want to listen to your favorite stations,In power-on state, press the buttons, You will quickly enter the station. Save time.
❤Memory Function ☛This transistor radio has memory function, Can remember the radio stations searched and saved before.It use 2 AA /um-3 batteries.LIJIANI-218wb.mini Compact radio;Pocket Transistor radio.small handheld radio mini.
❤Digital Clock Function ☛the transistor radio has the function of digital alarm clock. And you can set an alarm clock in advance, when the time is up, it will automatically play the radio station that you want to listen to. the radio has an electronic LCD display, supports am/pm time, radio frequency, and band digital display.
