NOAA Emergency Weather Alert Radio, 5000 Large Capacity Hand Crank Solar Powered AM/FM/Shortwave Radio for Home, Portable LED Camping Flashlight Reading Lamp, Phone Charger Earphone Jack,SOS Alarm
Price: $39.99
(as of Apr 03, 2025 11:45:22 UTC – Details)
【5 Ways Powered Emergency weather Radio with 5000 Large Capacity Built-in Battery】The rechargeable weather radio supports powered by AC/DC power, solar, hand crank, 3* AAA batteries (not included) & built-in replaceable 5000 battery(included). And there is a battery icon on the LCD display to inform you the battery level so you would never worry about a sudden power outage. The built-in 5000 battery could help you to charge your phone or other devices to in a emergency to avoid lost contact.
【3 Mode Ultra Bright Flashlight, Reading Lamp& SOS Alert Light】 The flashlight on the left side and the foldable reading light on the top all have two adjustable brightness levels for your choices. You could take it for hiking, camping, fishing or other outdoor activities. Or if there is a power failure, you could also turn it on for emergency use, necessary for areas with frequent power outages. And the red SOS alert light can be also manually turned on in an emergency to ask for help.
【2 Weather Alert Modes with Auto Weather Alert & Manual SOS Alert】 This is a must-have radio for your 𝗲𝗺𝗲𝗿𝗴𝗲𝗻𝗰𝘆 𝗸𝗶𝘁. Once the weather radio receives a weather alert, the radio will come out a siren,and the red alert light, the Alert icon as well as the backlight on the LCD display will flash to alert you. You could also easily press the SOS button to ask for help in an emergency. The loud SOS siren and the flashing red light will make you more likely to be found by the rescue team.
【A lot of User Friendly Details】The USB phone charger makes you always in touch. The 3.5mm earphone jack won’t let you be disturbed when listening to the radio. The hook and the wrist strap make it a portable radio for 𝗼𝘂𝘁𝗱𝗼𝗼𝗿 uses. The battery indicator could inform you keeping the radio working continuously. The lock button will prevent accidental press, great for families with babies. And the adjustable volume function will always satisfy your preference.
