NEXPOW Portable Power Station 2000W/2400Wh LiFePO4 Lithium Battery Pack ,Solar Generator(Solar Panel Not Included)with Anderson interface,60W PD and 110V/2000WAC Outlet for Home Outdoor Camping RV use
Price: $999.00
(as of – Details)
Wattage
2000 watts
【VERSATILE POWER SOURCE】: Our power station is equipped with a variety of ports, including a USB-C output, USB-A socket, three AC power sockets, two DC12V cigarette lighters, an Anderson interface (max 30A), and an input 7909 port. These ports meet your needs for using a variety of electrical appliances. With overcurrent protection, the portable power station provides all-around protection to avoid overcurrent, overvoltage, and over-temperature, ensuring that you and your devices are safe.
【Upgraded Protections & 3 Recharging Options】: NEXPOW has configured its own intelligent cooling system with a cooling fan for quick heat dissipation, creating a cooler and safer environment for the battery. It protects the safety of circuits and ensures efficient and safe charging of your devices and small appliances. The electricity generator supports 110V AC outlet, solar panel, and car charging, providing you with maximum convenience.
【Smart LCD Screen & Advanced LED lighting】: The LCD screen can display the charging status and current state in real-time, making it convenient for you to check at any time and anywhere. The LED light has two lighting modes and gives you confidence in any emergency or unexpected power outages, meeting your various power needs. Our portable power station is a must-have for your home and outdoor activities.
【WHAT YOU GET】: Purchasers will get a 2000W power station, a car charging cable, a power adapter, and a manual. If you have any questions about our solar power station, please feel free to contact us, and we will reply within 24 hours.
【Warm Reminder】: The maximum supported PV (solar) watt input is 200W. When charging the product, it is not recommended that the AC outlet be used to output high-power products, The use of electrical appliances must be within the power range, and products that exceed the power range cannot be used, which will damage the portable energy storage power station.
