Price: $39.99
(as of Apr 16, 2025 23:15:20 UTC – Details)
【Patented Knob】This is probably the best knob you have ever used. It is ergonomically designed. Enlarge the knob and place it on both sides of the radio for easy operation with both hands. At any time, convenience is the key factor of emergency products. We are sure that this patented design will satisfy you.
【Upgraded Classic Features】4000mAh rechargeable battery can charge more than one smartphone, 1.5W led flashlight Mode & SOS Alarm Flashing Mode,sharp SOS alarm system, 4 battery charging lights (25% 50% 75% 100% power indicator). IPX3 water resistant.
【3 Way Power Sources】 Including Hand Crank, Solar Panel, Type C Cable. Type C cable can quickly charge the radio. The radio’s crank lever and solar panel are both capable of regenerating enough power to keep the radio, lights, and SOS alarm ready to go when you need it most.
【FM AM NOAA】Super strong signals, The radio will dependably receive up to emergency weather forecasts and emergency news broadcasts from AM/FM stations and NOAA .
【Top Chip】It is superior to the top chip of similar products in the market. With more comprehensive reception signals, you will receive more radio stations and get better entertainment experience. And get longer use life of the solar radio.
