Price: $35.99
(as of Apr 05, 2025 00:30:29 UTC – Details)
Product information
Name:hand-cranked multi-function radio
Weight:225g
Color:white
Charging mode:hand-cranked,solar,DC
Function:Lighting,emergency alarm,phone charge,AM/FM radio
Bulb Type:LED
Applicable environment:Daily carrying,camping,hiking,night riding,emergency response
Solar power:5.5V/40 mA(under 20000lux Sun)
Hand-cranked power:1.5-2.0W(hand-cranked 120-150 rpm)
Mobile charging:DC OUT 5V,max 500 mA
External MICRO USB charging interface
Manual Power Generation Instructions:
Can be at any time hand-cranked.When no electricity,the hand-cranked power 3 minutes,approximately can illuminate 15-12 minutes or use the radio 6-8 minutes(the faster the hand-cranked generation efficiency is higher)
Mobile phone Charging Instructions:
Please use the phone original charge line,suggest that the handset low battery,when the handset is turned off after the hand-cranked charge,can achieve the best effect.The handset consumes power when standby,the charge effect will weaken.the effect will be weakened.Different brands,capacity mobile phone charging effect is different,Special Iphone & Samsung charging requirements are relatively high,Requires a high speed to meet their charging voltage
External Power charge Description:
The product does not contain charger,it is recommended to use the mobile phone charger to recharge(5V charger can).The 500 ma capacity is about 2 hours full,the product does not have full electric prompt,but has the circuit protection,does not have the overcharge and so on the security question.
Radio PRECAUTIONS:
When using AM/FM,swing the antenna,carefully debug.Please ensure that the local radio signal good,reception good environment,(car parks,basements,high-rise buildings,forests,remote areas,strong magnetic fields will have an impact on the radio reception)
【AM/FM radio】- AM has a greater reception range than FM shortwave radio, keeping you up to date on the latest weather such as earthquakes, hurricanes, tornadoes, and severe storms. While FM can receive entertainment, sports, talk shows and news more clearly. When using AM/FM, please swing the antenna and adjust carefully. Please ensure that the local radio signal is good and the receiving environment is good (parking lots, basements, high-rise buildings, forests, remote areas, strong magnetic fields, etc. will affect radio reception)
【Multifunction】- This radio not only has FM/AM radio function, but also supports LED lights, SOS alarm and 4 charging methods, in addition to that, it can also charge mobile phones through the USB port, which is an indispensable tool in emergency situations.
【Portable Radio】- Only 15.7*9*5.5cm, 279g. The compact and portable design allows you to take it with you wherever you go. You can put it in your bag or in the car.
【Note】- When not in use for a long time, please set the switch to “battery”. And regularly charge the built-in lithium battery to ensure the service life of the built-in lithium battery. If you have any questions, feel free to contact our customer service team, we will reply within 24 hours!
