Monteka Electric Lunch Box Food Heater Upgrade 60/80/100W Double Layer Portable Food Warmer, 12V/24V/110V Heated Lunch Box for Adults Car Truck Home with 1.8L Removable Stainless Steel Container
Price: $34.99
(as of Feb 28, 2025 23:00:31 UTC – Details)
Stronger Leak-proof Properties – The electric lunch box cover has latches on all four sides, and its coverage area is designed to be larger, making it stronger and not breaking easily. And the built-in rubber sealing ring can ensure that the food will not leak during transportation and keep the food fresh! No need to worry about food spills, even in a shaky car environment!
Enjoy Healthy Warm Food! – Made of premium food-grade material, it is the best heat lunch box container for packing healthy food. The outer shell has strong heat resistance, even if the internal temperature reaches 100 degrees, it will not be hot! 304 stainless steel for the inner tank has no odor and is durable, reusable, and easy to clean!
4-in-1 Portable Food Warmer – It is equipped with 2 power adapters: a 110V/220V home indoor adapter, a 12V/24V car, and a truck adapter. Plugin the power to heat up the food, it can be used at home/school/office/car/truck. Let you enjoy fresh and hot meals whether you are working outdoors or indoors! This is also an ideal warm gift for family and friends!
Max 100W High-power & Fast Heating – Electric lunchboxes for adults adopt a PTC heating system, with constant temperature and low heat consumption cycle function, it can keep the food heated evenly and also lock the moisture of the food. It only takes 20-35 minutes to quickly heat up to the optimum temperature, enjoy a fresh home-cooked meal! Eliminate the fatigue of your day!
