MOMSIV 12oz Travel Mug, Insulated Coffee Cup with Leakproof Lid, Vacuum Stainless Steel Double Walled Reusable Tumbler for Hot and Cold Water Coffee and Tea In Travel and Car (Black – 380ml)
Price: $14.99 - $9.56
(as of Jan 27, 2025 17:00:41 UTC – Details)
[ Easy to Drink with One Hand ]: Travel coffee mug includes an eco-friendly flap opening that makes drinking one-handed a breeze. And the surface of the lid also has a straw hole design, which allows you to drink straight from the cup or use a straw. Comes with a silicone cover on the body, it can help you hold it comfortably.
[ Reliable Screw-On Leakproof Lid ]: It uses a screw-on lid design, which can click securely into the closed position. If the lid latched, you can turn the travel cup at any angle with confidence and don’t need to worry about it will spill and cause leaks in your travel or office bag. Just bring your beverages to go!
[ Non-slip Rubber Cushion ]: There is a rubber cushion on the bottom of this coffee cup that helps stop it from sliding about and protect furniture from scratches and chips. Also, the flip-top can be fixed to the other side, so you don’t need to worry that it would hit your nose when drinking.
[ Excellent Performance at Many Occasion ]: 380ml/12oz capacity is a portable travel mug when you are on the go. It is still lightweight even it is full of beverages. And the lid of this cup has a protruding part so it is easy to find the hole without looking when driving. A good ideal for indoor and outdoor use, such as home, travel and car.
