Price: $69.99
(as of Apr 10, 2025 11:00:34 UTC – Details)
Mobile WiFi Hotspot | KuWFi 4G LTE Unlocked Wi-Fi Hotspot Device | Portable WiFi Router with SIM Card Slot for Travel Support B2/B4/B5/B12/B17 for AT&T/T-Mobile
【Work Mode & Band】portable wifi device work with 4G to WiFi, Support 4G FDD B2/B4/B5/B12/B17. WCDMA:B1(2100Mhz).Network Frequency Mainly applicable to USA/Canada/Mexico, portable wifi hotspot for travel
【Easy to Connect】This Travel Partner WiFi Hotspot is Easy to connect and easy to carry in hand Sharing customer Up to 10 User with 50M distance. All you need to do is inserting the SIM card, then you will enjoy the WiFi with your friends with this portable 4G LTE router
【Tips on product using】insert SIM card then Install the battery (tear off the insulating film). Even if your SIM card is compatible with the hotspot wifi devices, it is not necessarily plug and play, you may need to disable the PIN code of the SIM card and modify the APN .Enter the router IP address: 192.168.0.1—Click Network—APN—Enable. Modify APN. Make sure the SIM card is activate, Not support roaming service and Virtual SIM Card and IoT SIM Card
【Customer Service】For 30 days after the date of purchase, return your undamaged KuWFi portable wifi box and receive a full refund for ANY reason.12-month warranty for quality-related issues For 12 months after the date of purchase we take care of all quality-related issues with a REPLACEMENT OR FULL REFUND
