Price: $74.99
(as of Aug 10, 2024 18:00:22 UTC – Details)
36 Channels 121 Privacy Codes Water Resistant Xtreme Range* – Up to 30 miles Channel Scan Weather Alert Radio & Weather Scan HI/LO Power Settings Headphone Jacks
LXT633VP3 Two Way Radio
Powerful and consistent choice for your radio communication needs.
The LXT633VP3 walkie talkie ensures crisp, clear communication. Featuring signature Weather Scan + Alert Technology – NOAA Weather Scan automatically scans through 10 available weather (WX) band channels, lock onto the strongest weather channel, and sound an alarm indicating that there is a risk of severe weather in your area. Other features include: 22 channels plus 14 extra channels with pre-programmed privacy codes, 121 privacy codes, channel scan, and silent operation.
In the box:
3 Radios Belt Clips Rechargeable Battery Packs Desktop Charger AC Wall Adapter Dual Pin Charger Owner’s Manual
36 Channels + Privacy Codes
Clear, crisp communication on up to 2662 channel options to help you block other conversations.
Lets you adjust transmit power & conserve battery life.
Silent Operation
Turns off all tones for quiet operation.
Hands-Free Operation
Easy voice and sound activated transmission (eVOX) for 3 levels of hands free operation.
Cross Compatible
Compatible with all Midland FRS and GMRS walkie talkies and accessories.
NOAA Weather Scan + Alert
Automatically scan weather band channels and alert you of severe weather updates.
Long Range
Longer range communication in open areas with little or no obstruction.
Product Dimensions : 4 x 10 x 12 inches; 1.68 Pounds
Item model number : LXT633VP3
Batteries : 18 AAA batteries required. (included)
Date First Available : May 5, 2017
Manufacturer : Midland
ASIN : B0745DYBQV
Country of Origin : USA
DUAL POWER AND EXTENDED RANGE – Dual power options mean that these radios can be powered by either rechargeable batteries or disposable batteries, usually AAA or AA batteries. This provides more flexibility in terms of power options and allows users to have a backup power source if the rechargeable batteries run out of charge. Up to 3o Miles of Range – Longer range communication in open areas with little or no obstruction
121 CTCSS PRIVACY CODES – The Continuous Tone-Coded Squelch System gives you up to 2,662 channel options to help block other conversations. Use silent operation to turn off all tones. Commonly used for outdoor activities, such as hiking, camping, and skiing, where cellular coverage may be limited or not available. They are also used in various settings, such as construction sites, warehouses, and schools, for communication between team members.
NOAA Weather Scan & Alert – NOAA Weather Scan will automatically scan through 10 available weather (WX) band channels and locks onto the strongest weather channel to alert you of severe weather updates.If the National Weather Service issues a severe weather alert for your area, the radio will sound an alarm.
