Price: $139.99 - $78.99
(as of Feb 05, 2025 03:45:18 UTC – Details)
MARBERO Portable Power Station 83Wh Small Generator Solar Power Bank 80W(Peak 120W) Camping Laptop Charger Emergency Battery Pack with AC Outlet 4 USB Ports with Flashlight for Outdoor Home Travel
MULTIPLE PURPOSE: This power supply is built in lithium ion battery with 22500mAh(83Wh) power bank which is powerful enough to meet different needs of appliances, electronics, such as cell phone, suit for iPhone, Samsung, Tablet, camera, mattress pump, radio, night light, mini fan and others under 80W.
COMPACT&CONVENIENT: With the small size(5.7*5.6*2.7 inches) and light weight(2.2 lbs), this mini generator with leather handle design will save a lot of space in your bag or luggage which is really convenient for camping, hiking, fishing, business trip, tailgating party, etc.The portable power station can be used not only for daily life charging, but also for outdoors or wherever energy is needed in case of urgency.
ULTRA BRIGHT LED: The ultra-bright LED light of the portable power bank has 3 lighting modes, constant, twinkling and SOS mode. Also there are 4 levels of brightness. Working as an essential kit for night lighting and emergency work, it emits a maximum of 7W and 562 lumens for 13hrs on full charge, which can illuminate 215 square feet for your bedroom and office during blackout or power outage. Moreover, in the lowest brightness level which is 0.7W and 40 lumens, it will run for approx. 94hrs.
3 CHARGING METHODS: The laptop power charger is designed with 3 rechargeable methods.On the wall, you can fully charge the solar powered bank via AC outlet(adapter included) within 5 hours. And the power station could be recharged by cigarette 12V outlet.Or it can be charged under the sun with MARBERO solar panels (15V-24V, 1.2A).
MULTI-OUTPUT: This portable generator is equipped with 2*QC3.0 USB port (27W max), 2*USB C (PD3.0, 18W/30W Max). 1*DC ports (5V/4.8A 24W max), 1*AC output (80W running, 120W peak). AC output is designed for laptop, MacBook, fan, CPAP, lamp and etc
SECURED & ASSURED: The Battery Management System(BMS) allows for voltage control, temperature control and more advanced safety operations. Designed with the cooling vents on the back to help this portable power supply keep the temperature constant, its internal electrical elements will not be damaged by high temperatures. When it comes to short circuit or overload, it automatically shuts off the current to protect the powered devices.
