MARBERO Portable Power Station 150Wh Camping Solar Generator Laptop Charger with 110V 150W Peak AC Outlet, DC Ports, USB Ports LED Flashlights for CPAP Home Camping Emergency
Price: $99.21
(as of Apr 02, 2025 20:15:20 UTC – Details)
MULTI-OUTPUTS: The portable power station is equipped with 3*USB port(5V/2.1A Max),1*QC3.0 USB port(4V~9V/2.1A Max), 4*DC 55*21 port(5~12V/10A with 15A MAX) and 1*AC output socket(100W with 150W peak) which can simultaneously charge your smart phone, iPad, tablets, camera, radio, night light, mini fan and camping essentials under 100W which is perfect for meeting, camping and emergency.
PRO FLASHLIGHT: There are 2*LED flashlights built-in on the side of the power station with 2 lighting modes(steady light and flashing SOS light). Press the LED flashlight switch to change the 2 modes. When you go out camping or experience power outages, this function may help you out.
3 RECHAGRGING WAYS: There are three methods to charge this portable power station. The package includes two adapters, you can charge it by wall outlet or by car adapter(12V). Or it can be also recharged under the sun with a solar panel(15V~24V/1.2A)(not included).
SECURED & ASSURED: With the technology of Battery Management System (BMS), it enables the voltage control, temperature control and more advanced safety controls. Designed with the cooling vents on its back to help this portable power supply stay in a constant temperature range by avoiding internal electrical elements to be damaged. When it comes to short circuit or overpowered, it will automatically and immediately shut off the power to protect itself and the powered devices.
