MARBERO 88Wh Portable Power Station 24000mAh Camping Solar Generator(Solar Panel Not Included) Lithium Battery Power 110V/80W AC, DC, USB QC3.0, LED Flashlight for CPAP Home Camping Emergency Backup
Price: $109.99 - $99.99
(as of Apr 12, 2025 07:15:23 UTC – Details)
Wattage :
80 watts
🔌MULTI-OUTPUT: The portable power station equipped with 88Wh (24000mAh, 3.7V) capacity, 2*QC 3.0 USB ports (18W max), 2*USB ports (5V 2.4A), 1*USB C port (PD2. 0.18W max). 1*DC port(12-16.8V / 10A, 13A max), 1*2 pole and 1* 3 pole output socket (80W running, 120W peak). Powers cell phone, iPad, tablet, camera, radio, USB powered night light, mini fan and camping scanners under 80W.
💡EMERGENCY LIGHTS: This portable generator is built with a 3-level brightness LED flashlight, which could emit 2 lighting modes (steady light and flashing light, SOS mode) to meet your different needs. Press the LED flashlight switch to change the brightness and SOS mode. When you go out camping or experience power outages, this power supply can always help you out.
🔋TWO RECHARGING MODES: 88Wh portable rechargeable power station with two methods to charge the portable power station. On the wall, you can fully charge the power supply via AC outlet (adapter included) with 5 hours. Or it can be charged under the sun with a MARBERO solar panel(15V-24V, 1.2A)(not included).
🛡️SECURED & ASSURED: The Battery Management System (BMS) allows for voltage control, temperature control and more advanced safety operations. Designed with the cooling vents on the back to help this portable power supply keep the temperature constant, its internal electrical elements will not be damaged by high temperatures. When it comes to short circuit or overload, it automatically shuts off the power to protect itself and the powered devices.
