Price: $59.49
(as of Mar 29, 2025 08:30:30 UTC – Details)
A Perfect HDTV Antenna with Omni Directional Design!
The HIDB 1080p HDTV reception tv antenna ensures that you always have the highest quality content. You no longer have to pay hefty bills for multi-channel television each month. You’ll enjoy popular national TV networks and local TV shows at no cost!HIDB omnidirectional antenna is simple to install on your RV or travel trailer. Designed for strong signals without requiring pointing.
Omnidirectional Over-the-Air HDTV Antenna!
360 degree Omni-directional reception, designed for Mobility!.
Build-in high gain low noise signal amplifier.
Channels in crystal clear HD quality.
180 mile long range with amplifier.
With magnetic base antenna, set-up in minutes with no tools
Anti-UV coating and waterproof design for durability.
16 ft longer coaxial cable for various places.
180 Mile Range Outdoor TV Antenna for Digital TV!
The amplified signal maximizes signal strength to provide the best TV reception available in your area. Manufactured with durable plastic, the antenna is weatherproof, UV-protected and resistant to rust. It’s designed to withstand your outdoor.
Smart chip!
Build in 4G LTE Filter shields against interference and blocks unwanted 3G and 4G wireless signals for stable performance. Enjoy smooth and crystal clear 4K HDTV experience.
How to Scan Channel?
Mount the antenna on your Car roof for optimal performance.Consult related instruction manual to SCAN the Channels FIRST if you use a digital converter boxFind the setting option on TV menu. Set up the signal source to AIR/Antenna.After you set up the signal source, go to Channel Scan or Channel Manage to scan the digital channels.
Warm Tips for You!
Channel selection and picture quality is dependent on broadcast strength and location. Antenna reception and picture quality may also be affected by local terrain and obstructions such as hills, mountains, buildings and trees. Enter your address into a website such as tvfool or dtv.gov/maps for channel listings in your location.
【RV Mobile Use】This antenna is Omnidirectional Reception antenna. Designed for mobile use. This powerful antenna will provide the best picture and sound quality, even if your vehicle changes course, HIDB digital TV antenna can be used both indoors and outdoors and is especially perfect for RVs, trucks, boats, and caravans.
【Easy Installation】This digital TV antenna installing easy. it contains a big magnetic base that can make mounting it to your RV, car or boat quick and effortless. the digital antenna weather-resistant and UV-stabilized housing will protect it’s not be affected by bad weather.
【Minimal Interference】 The digital TV antenna provides a strong and stable connection with little to no intermittence. The included low-noise amplifier guarantees minimal noise interference in weak signal areas and from strong local signals by preventing overloading, the usual cause of picture distortion. The amplifier will help you receive perfect TV signal, enhancing the broadcasts detected by the antenna.
【HIDB Warranty】Our products tend to not require electricians to assemble. They are made of the best quality materials and produce the best quality results.We are confident in the quality of our product and offer Lifelong after-sales service and 30-day returning warranty. Please contact us for get more support.
