Price: $799.00
(as of – Details)
Adopting an automotive-grade ternary lithium battery called POWER BATTERY, the battery density of Rocket 1200 solar generator is 100Wh/kg higher than that of LiFePo4 battery. Larger capacity, faster charging speed and longer battery life offer you a better experience.
-Light Weight & Large Capacity
With a large capacity of 1110Wh and an output power of up to 1200W, Steelite portable power station supports all electronic devices and appliances below 1200W. Adopting lightweight ternary lithium battery, it weighs only 11.2kg, lighter than those of the same capacity in the industry, more convenient and easier to take it outdoors.
-Charge Multiple Devices Simultaneously
Rocket 1200 home battery backup has 13 output ports in total – 6 AC sockets, 2 USB-C ports, 1 QC3.0 port, 1 USB-A port, 2 DC ports and a car outlet. Use it to charge all your devices at once just in one place, efficient and convenient.
-Double Protection
The internal batteries are protected by 2-layer case, combined with aviation aluminum alloy shell and inner frame, this 1200W portable battery generator is strongly resistant to high and low temperature, corrosion and vibration.
Tips
– When the switch is turned on, there will be a certain amount of no-load power consumption even if no device is being charged. It is recommended to turn off the switch after use to avoid draining the battery.
– Please note that the AC output port can only charge or power devices that operate at less than 1200W.
ćFAST CHARGING-1.5 HOURS FULLY CHARGEDć–AC700W high speed charging, charging through wall socket, as fast as 1.5 hours. Built-in professional MPPT technology for efficient solar charging management, can use up to 500W solar panel for charging. Charging in the field with solar panels (sold separately) takes as little as 2.5 hours (500W input power). Charging via 700W AC input and 500W solar panel simultaneously takes only 1 hour.
ćOUTDOOR FOR EMERGENCYć– You will never be left in the dark with this power and its exquisite and high-end package makes it a perfect gift for friends as power outage supplies. Winter storms always make power failure a real possibility, this power station may help you a lot in winter emergencies when stuck in a car or at home.
ćPOWER UP TO SIMULTANEOUSLYć–Allows to power devices up to 1200W, including laptops, phones, tablets, fans, drones, car fridges, LED lights, digital cameras, and more. Please conduct a full test on a case-by-case basis to see if the station feature can work with your appliances.
ćSafety &Durableć– The ultra-safe LiFePO4 battery with Build-in BMS assure the self-protection of short circuit, overload, and overheat. 120V Pure-sine wave inverter make sure there is no damage to your sensitive electronic devices.
