KuWFi Whole Home Mesh WiFi System 3-Pack AC3600 High Speed Seamless Roaming WiFi Network Dual Band 2.4G&5.8G Router for Whole Home Coverage
Price: $99.98
(as of Apr 07, 2025 20:00:33 UTC – Details)
Mesh WiFi System
Mesh WiFi System
KuWFi Dual-band AC3600 MESH+ WiFi Kit (E05ME+2*E05SE). Make WiFi Smarter, Turn Life Easier
Tech Specification:
Wireless Connectivity
–Radio 1: 400Mbps @ 2.4GHz: Supports 256QAM
–Radio 2: 866Mbps @ 5GHz: Supports 256QAM
80 wireless terminals with Peak Connection
IEEER 802.11a/b/g/n ,802.11ac wave2
MU-MIMO capable for simultaneous data streaming
Implicit & Explicit Beamforming for 2.4GHz & 5GHz bands
WiFi Security: WPA2/WPA
Solution:
–Qualcomm QCA9531
–16MB Flash
–128MB DDR2
Core Technology: MESH+ Wi-Fi SON
Antenna: four (4) high performance internal antennas
Link LED Status (Router)
–Color Red ON:Weak WiFi Signal
–Color Blue ON: Strong WiFi Signal
Link LED Status (Node)
Dimensions: 180mm*144mm*94mm (each)
Weight: 205g (each)
Dual-band Concurrency (5.8G & 2.4G):
Industrial Qualcomm chipsets
Multiple devices for high-speed lossless broadband Enhance users’ online experience
Software Function:
Web Service and mobile App, provide the better user experience of setup and management.
Safe Wi-Fi Setting
Parental Control
Speed Test
Client management
Data Statistics
Network Map
Mesh WiFi System
Mesh WiFi System
Mesh WiFi System
Mesh WiFi System
Mesh WiFi System
Mesh WiFi System
Kvr Seamless Roaming – For villa
As an AP, use it to support 802.11k/v/r and cooperate with terminal equipment Enable WiFi seamless roaming in multiple floors
Up to 50 users
A single device supports 50 users.Intelligent load balancing Improve broadband utilization Improve overall throughput
Kvr Seamless Roaming – For Ohira layer
As an AP, use it to support 802.11k/v/r and cooperate with terminal equipment Enable WiFi seamless roaming in Multiple rooms
Ethernet Ports (Router)
One (1)10/100Mbps Fast Ethernet WAN port
One (1)10/100Mbps Fast Ethernet LAN port
Reset & Sync Button (reuse)
What’s in the package?
One (1) MESH+ Router (E05ME)
One (2) MESH+ Node (E05SE)
One (1) 1m Cat5e Ethernet cable
Two (3) DC12V/1.5A power adapter
Quick start guide
Ethernet Ports (Node)
Two (2) 10/100Mbps Fast Ethernet LAN ports
Heartwarming tips:
Maximum wireless signal range derived from IEEE standard 802.11 specifications. Actual data throughput and data over distance will vary. Network conditions and environmental factors, including volume of network traffic, building material and construction, and network overhead, result in lower actual data throughput rate and wireless coverage.
【Features】No dead-zone to reach all corners: With high performance antennas and most effective design, the signal reaches any places. Meanwhile, new Wi-Fi technology makes it flexible to extend signal range with Wi-Fi Node. Simple design for family life: External beauty, shape, aesthetics, extraordinary design. Display everywhere and immerse the residential style
【High speed WiFi】up to 3600Mbps & Seamless roaming: Dual-band 2.4G & 5G WiFi, mesh wifi system provide wider data lane and reliable & fast WiFi for 4K / 8K streaming video or game needs. Never feel terrible interrupt and lag while you are in calling or gaming through different rooms
【Plug and Play】Whether you’re comfortable with technology, or dread setting up new gadgets. In under 10 minutes, you can get amazingly fast WiFi. Start by plugging the mesh wifi router directly into the modem
【After-sales service】For 30 days after the date of purchase, return your undamaged product and receive a full refund for ANY reason.12-month warranty for quality-related issues For 12 months after the date of purchase we take care of all quality-related issues with a REPLACEMENT OR FULL REFUND
