KuWFi 4G LTE USB WiFi Modem Mobile Internet Devices with SIM Card Slot High Speed Portable Travel Hotspot Mini Router for USA/CA/MX
Price: $258.99
(as of Apr 11, 2025 02:00:31 UTC – Details)
【Main features Performance】supports the LTE CAT4 standard, 150 Mbps high-speed Internet access, but mainly depends on the strength of the signal. It has a SIM card slot, and a USB interface. It work with external power supply, no limited working time. It can charger by computer USB port/ Power Bank / Car USB charger/Power supply. No need to install driver. If the WiFi dongle works for a long time, it needs heat dissipation. Otherwise, it may cause the chip to burn out
【HOW TO USE 】Even if your SIM card is compatible with the 4G WiFi Dongle, it is not necessarily plug and play, maybe you need to disable the PIN code of the SIM card and modify the APN . Please you make sure the SIM card is activate, It not support roaming service and Virtual SIM Card and IoT SIM Card; In rural area did not cover good signal some time disconnect ,that is normal
【4G network band 】this 4G LTE USB Modem is compatible with the frequency bands of SIM cards in USA/CA/MX. Frequency Bands: 4G FDD-LTE: B2(1900Mhz),B4(1700Mhz),B5(850Mhz); 3G: B2/B4. It’s not plug and play, please you confirm whether your SIM card frequency band is compatible with it before buying a router
【Customer Service】For 30 days after the date of purchase, return your undamaged KuWFi product and receive a full refund for ANY reason.12-month warranty for quality-related issues For 12 months after the date of purchase. we take care of all quality-related issues with a REPLACEMENT OR FULL REFUND
