Price: $21.99
(as of Apr 10, 2025 22:00:32 UTC – Details)
KeyUnity KM11 Titanium Key Holder Belt Clip, Double Side Carabiner Keychain For Men
SPECIFICATION
Keychain material: Ti-6Al-4V titanium alloy
Key ring material: 304 stainless steel
Surface treatment: Sand blasted stone washed
Total length: 75mm
Total weight: 17g
Key clip length: 56mm
Key clip width: 20mm
Key clip thickness: 9mm
Key ring diameter: 25mm
FEATURES
1.Well made. CNC machined from full titanium alloy, sandblasting stone washing outer surface process, make it light and strong.
2.Ingenious design. Take the advantage of the toughness of Ti, the spring is one-piece molding, make this keychain more durable.
3.Dual gate design. Special oval structure, two end accessible. It makes assembly and disassembly more convenient while ensuring the security.You can securely clip valuables like keys to one side, then clip the other side to your backpack, belt loop or pocket.
Product Dimensions : 2.28 x 0.39 x 0.79 inches; 0.6 Ounces
Department : mens
Date First Available : August 30, 2022
ASIN : B0BCDT1VNS
Imported
Snap Hook closure
Dry Clean Only
PLEASE NOTE THAT THE KEY RING IS MADE OF 304 STAINLESS STEEL
【SMART DUAL GATE】 This titanium keychain carabiner offers large space to holds all your key rings with ease; Both end accessible, key rings are slipped in and out to one side, the other side is free to clip on and off your belt, pants loop or backpack without disturbing your keys, effectively keep your keys secure in place, never lost your keys again.
【INNOVATIVE SPRING STRUCTURE】 Take the advantage of the toughness of Ti, without using traditional twisted spring, make this keychain hook overall structure more durable and hard to be deformed.
