KeyUnity KM00 Titanium Belt Loop Keychain Clip Double Side Quick Release Key Holder with Detachable Key Ring
Price: $21.99
(as of Apr 08, 2025 02:00:32 UTC – Details)
Don’t add the bulk to your keys!
Use this keychain clip to make a quick and easy access to key rings
SPECIFICATION:
Material: Ti-6al-4v Titanium Alloy
Craftmanship: Sand blasted stone washed
Key clip length:2.2″ (58mm)
Key clip width:0.39″ (10mm)
Key clip thickness:0.78″ (20mm)
Key clip weight:10g±1g
Key ring diameter:1.1″ (28mm)
Key ring thickness:0.11″ (3mm)
key ring weight:2g
SPECIAL FEATURE:
1. Quality material. Made of full TC4 titanium alloy. The wide of the product is 10mm with thickness of 1.35mm, which is light and strong.
2. Ingenious design. Adopt with unique S shape bending structure, simple and easy to use, it makes assembly and disassembly more convenient while ensuring the strength.
3. Double-sided mounting. Without using the traditional twisted spring, one-piece molding, both ends can clip on the belt.
PACKAGE CONTAINS:
KM00 Titanium key chain clip x1
Key ring x1
Brand sticker x1
User manual x1
Product Dimensions ‏ : ‎ 2.28 x 0.39 x 0.79 inches; 0.35 Ounces
Department ‏ : ‎ mens
Date First Available ‏ : ‎ March 10, 2022
ASIN ‏ : ‎ B09V6G72BJ
Imported
Pull On closure
Dry Clean Only
【DURABLE MATERIAL】 The EDC keychain belt clip is made into one part; Forged from sturdy Ti-6al-4v titanium alloy, super lightweight (0.45oz), 4x strength of stainless steel, non corrosion and non-metallic smell
【PVD BLACK COATING】 Special PVD black coating will make this keychain more durable and elegant.
【QUICK ACCESS & SMART】 This belt key holder attached with a titanium key ring, key rings are slipped in and out extremely easy, never lost your keys again
