Kasa Smart Light Switch HS200, Single Pole, Needs Neutral Wire, 2.4GHz Wi-Fi Light Switch Works with Alexa and Google Home, UL Certified, No Hub Required , White
Price: $19.99 - $16.99
(as of Mar 14, 2025 19:30:28 UTC – Details)
Leading Smart Home Brand
Product Dimensions ‏ : ‎ 1.5 x 3.3 x 5 inches; 5.28 Ounces
Item model number ‏ : ‎ HS200
Date First Available ‏ : ‎ June 1, 2016
Manufacturer ‏ : ‎ TP-LINK USA
ASIN ‏ : ‎ B01EZV35QU
Country of Origin ‏ : ‎ Vietnam
Control from anywhere: Monitor your light status. Turn electronics on and off from anywhere with your smartphone using the Kasa app, whether you are at home, in the office or on vacation
Voice control: Enjoy the hands-free convenience of controlling the lights in your home with your voice via Amazon Alexa or Google Assistant; perfect for times when your hands are full or entering a dark room
Scheduling: Use timer or countdown schedules to set your smart switch to automatically turn on and off while you’re home or away. Enable ‘away mode’ to randomly switch on and off to trick potential intruders
Trusted and reliable: Designed and developed in silicon valley, Kasa is trusted by over 4 million users. UL certified for safety use. Dimensions without panel 4.13*1.71*1.74 in. (105*43.5*44.21 mm)
