Price: $199.98 - $259.89
(as of Mar 20, 2025 06:15:18 UTC – Details)
All-In-One Surveillance System Included:
1 x 4CH 1080P Mobile DVR.1 x accessory for MDVR.4 x 1080P AHD NTSC mode car camera2 x 35FT 4 pin cable, 1 x 15FT 4 pin cable. 1 x 50FT 4 pin cable.1 x 7 inches IPS VGA car monitor.Note 1: memory card NOT Included.Note 2: We have longer cable to choose.
Hassle Free Connection
Connect the car cameras with mdvr via 4-pin connector cables. Power the MDVR via the car battery/ACC. Connect 7″ monitor with the MDVR via VGA connector. Power the monitor via the 12VDC output cable of MDVR.
4-CH 720P Loop Recording
4-channel 1080P loop recording. If set record resolution at 1080P. I will use 1.0G storage for one camera to record one hour. It also setup recording resolution at 720P/960H/D1/CIF to save space.With 1 memory card slot. supports maximum 256 GB . Please use BIG SIZE memory card not the TF card.Convenient to palyback videos on mdvr. also supports to backup video from USB slot.
Easy Mount
Just drill a hole in your vehicle and adjust the angle of the lens to a suitable direction.Camera used high-quality metal materials, can effectively prevent rust, Can be installed outside vehicle. 2.8mm lens. 120° wide view angle.
Hassle-free Service
Free new item to replace any defective item. Do not need to return the goods. Support to DIY the kit for your vehicle. Different mdvrs, cameras and cable length to choose.
Easy Setup
1080P MDVR
Easy Mount
Suport DIY
Infrared Clear Day Night Vision
Featuring 2.8mm LEDs with IR-CUT function, 120° viewing angle, 50ft Night Vision range.The camera’s infrared mode is automatically activated in low lighting conditions. It can clearly monitor everything even at night.
IP68 Waterproof Camera
The AHD cameras are rated as dust tight and waterproof and cover with durable housing. Not afraid to brave the snow, rain, or heat.AHD cameras’ operating temperature can be ranged from -40°F to 122°F (-40°C to 50°C)
DELAY POWER OFF
Records footage while vehicle is offâ up to 24 hours (draws power from vehicleâs battery).
4-CH Alarm Trigger Signal Input
The DVR supports 4-CH I/O inputs and 1 alarm output. It can set those inputs to record vehicle backing, turning left/right, door openning and more. Also, they can be simply used as a panic button, or work with other external sensors to trigger recording or send out alarm signal to external device.
Mirror Image
Supports horizontal and vertical flip image on each channel.
It can set multi-mode diaplay. 1CH/2CH/3CH/4CH.
3 Ways Playback Videos
1. Enter menu to search and playback videos on MDVR directly. Also supports to fast forward and rewind.
2. Backup avi video from USB slot of mdvr. play via common player directly.
3. Backup H.264 files or just take out the SD cards. Playback the H.264 files on our player software. It supports to playback 4 channels video at same time.
Remote Live View
â
â
â
â
GPS
â
â
â
â
WIFI
â
â
â
â
4G
â
â
Storage
2 Pieces 256GB SD 2 Pieces 256GB SD 2TB HDD/SSD 2 Pieces 256GB SD 2 Pieces 512GB SD 2TB HDD/SSD
Screen size
7″ 7″ 7″ 7″ 7″ 7″
About JOINLGO
JOINLGO Co., Ltd. is an intelligent vehicle monitoring and security solution service provider. We have over 10 years experience in vehicle security system.
ăLOOP RECORDă: 4-CH 720P (1080P/960H/D1 for selection) real time record. Records camera feeds continuously, looping over oldest recordings when storage is full. Records onto one memory card – with 256GB capacity. (CARD NOT INCLUDED).PLEASE DO NOT USE MICRO SD CARD, PLEASE USE BIG SD CARDăPLAYBACKăSupport playback videos on screen. Support video searching function so that we can easily get files of a certain period. We also provide a free software, used to palyback recording files on Windows PC.
ăEXCELLENT CAMERAă: PLEASE CHECK THE PICTURE FOR THE SIZE OF THE CAR CAMERA. IP68 Rate waterproof, can work in outside directly. 18 pieces IR LED for night vision. Full metal case material, Real 2.0MP resoluiton. ăMIRROR IMAGEăIt can mirror image via OSD menu operation, it can set any channel’s image Horizonal Filp or Vertical Filp.
ă7″ IPS VGA SCREENăThe 7″ car screen is VGA connector. screen resolution: 1024*600.ă4-CH ALARM INPUTă: It supports 4-CH alarm inputs, the screen will show full screen of one channel automatically when recieve the trigger signal. Manually create alarms so that associated footage is overwrite protected.
ăDELAY RECORDINGă: Records footage while vehicle is off â up to 24 hours (draws power from vehicleâs battery). ăWorry-Free WarrantyăEasy-to-reach lifetime email support, 2-year warranty and 90-day money back guarantee. And you can always rely on our 24/7 customer service. 2 YEARS WARRANTY. Life-time repairment service.
