JOBON Lighter USB Rechargeable Electric Lighter Arc Plasma Lighter Windproof Flameless Metal Lighter with LED Battery Indicator (Navy Blue)
Price: $15.98
(as of Apr 18, 2025 01:45:20 UTC – Details)
✔【Rechargeable and Long lasting battery life】: This electric lighter uses a powerful lithium ion battery instead of fuel to create its plasma beams and make fire. This reusable and non-disposable lighters can be charged and recharged over and over with a USB cable, and the batteries last for up to 400 charges. LED battery display show how full the battery is and when need to charger it. Besides the electric lighters being convenient and super cool looking, they are also much more eco-friendly.
✔【Windproof and Ultra portable】: This USB electronic arc lighter incredibly compact and has a sleek design that can easily slide into your pocket, purse, glove box, or wherever you need to store it or take it. it may even be lightweight and smaller than you expect. And also, this windproof lighter is designed for outdoor use so whether you are camping, hiking, lighting a fire at the beach or anywhere else, it should feature a reliable ignition to get things going.
✔【Construction and Durability】: This lighter is entirely made of high-quality durable metal construction. Strong zinc alloy make it easy and safe to use, works well and feels very durable. By replacing your disposable lighter for a non-disposable and rechargeable electric lighter prevent plastic waste, you can reuse this lighter over and over again.
✔【Safety and Flame-less】: JOBON plasma lighter has multiple protection functions such as over-charge, over-discharge and overload. The maximum discharge time is 6s each time, and the power is automatically cut off after more than 6s. It needs to be closed and reopened lid to make it lighting. The electric candle lighter also backed by JOBON’s limited lifetime warranty, so if anything should go wrong with it under normal use, can replace it with no questions asked. Just contact with us directly.
