JEVSTU Electric Lighter, Candle Lighter USB Rechargeable with LED Display 360° Flexible Neck, Arc Plasma Electronic Windproof Flameless Long Lighter with Safety Switch Hook for Kitchen Grill, Black
Price: $9.99
(as of – Details)
Just Focus On Creat An Easy Life For You.
JEVSTU 360° Flexible Long Candle Lighter
Disadvantages of traditional lighters
⛔Normal lighters ignite fireworks may burn yourself accidentally!
⛔Normal lighters are difficult to ignite in bad weather or when you are outside, which will be a big problem!
⛔Are you worried that your child may light the candle without continuous supervision?
Don’t worry, all your problems will be solved by us now.
✅Our lighters have a long ( about 4.6 inches) flexible soft head that allows you to maintain a safe distance from the flame.
✅The Arc lighter adopt taser flameless plasma technology to protect the electric pulse from being blown out by strong wind or wet weather.
✅Our rechargeable lighter has safer 3-step switch button and hook which can be easily placed in a safe place away from kids. It’s the perfect companion for candles.
Package Included:
🛍️1 * 360° Flexible Long Candle Lighter
🛍️1 * USB charger cable
🛍️1 * Beautiful Gift Box
Tips:
– When the arc lighter is charging or not in use, slide the safety switch down.
– Do not expose to direct sunlight or temperatures above 120°F (49°C).
🕯️【USB Lighter & 360° Flexible Neck & Hook】The candle lighter adopts flameless plasma technology, suitable for use in strong wind and wet environments. It has a long flexible neck , which can easily rotate 360 degrees for different lighting needs.Long lighter has hook which can be easily placed in a safe place away from kids. It’s the perfect companion for candles.
🕯️【Arc Lighter & Wind & Splash Proof】The Arc lighter adopt taser flameless plasma technology to protect the electric pulse from being blown out by strong wind or wet weather. It’s the best choose for indoor and outdoor activities. It might make a bzzzz sound after switched on, that is is the sound of an arc breaking through the air. It is absolutely normal circuit operation, NO effect on regular use.
🕯️【Plasma Lighter & Triple Safety Protection】Usb rechargeable lighter uses plasma tech to replace harmful butane. Treble protection, you need to slide the safety lock, keep pressing the ignition button, the lighter will emit an arc. For safer, the electric lighter will shut off after 5s of being ignited. Note: It couldn’t get to ignite while charging.
🕯️【Grill lighter & Widely Used】The top part of the fireplace lighter wouldn’t get damaged by candle fire, you can just clean it. This bbq lighter has a beautiful box and is the best gift for family and friends. Perfect for travel camping, hiking, BBQ grill, candle jars, incense cone, gas stove, fireworks, fireplace, kitchen cooking, and so on.
