Price: $4.49
(as of Mar 17, 2025 17:45:16 UTC – Details)
Will you be prepared if there is a power failure or severe storm in your area? The JENSEN JEP-650 Self-Powered AM/FM Weather Band Radio and flashlight is a valuable tool designed to keep you up informed and out of harm’s way when there’s an emergency situation. The radio can tune in AM and FM frequencies, as well as NOAA weather channels whenever you need to check on the current conditions. It not only keeps you updated during severe weather or civil emergencies, but it also features a built-in siren that can alert others of your location if you’re lost or need assistance. The unit always has power by utilizing its top-facing solar panel or the side mounted dynamo crank. These power sources also mean that you don’t have to worry about a dead smartphone thanks to the built-in USB emergency charging port. The JEP-650 also features a back-lit easy to read LCD display, a metal carabineer for clipping to your backpack and a handy carrying strap with storage compartment.
Product Dimensions : 8.5 x 4.75 x 3.5 inches; 1 Pounds
Item model number : JEP-650
Date First Available : August 21, 2018
Manufacturer : Spectra Merchandising International, Inc.
ASIN : B088MHWND2
Weather Alert Indicator – Instantly Switch to Weather Broadcast When Alert Signal is received
Multi-function Blue Back-lit LCD Display with Clock, 5 Ultra Bright LED Flashlight and Siren
Headphone Jack, Rotary Telescopic Antenna, Metal Carabineer and Carrying strap Included, Built-in Speaker
Top Mounted Solar Panel for Charging, Low Battery and Charging Indicators, 1 Amp USB Port for Charging your Smartphone. 4-Way Power: Dynamo (Manual Charge), Solar, USB Charging Port or 3 x ‘AA’ (UM-3) (Not included)
