Price: $9.99
(as of Apr 13, 2025 09:00:32 UTC – Details)
Heavy Duty But Convenient Key Rings
One of the lightest hardness key chain (Main Part: 3.42×0.98×0.2 in, 1 oz). You can use the key chain do whatever you want, also the leather part can go into a finger.
Quick Release Carabiner Clip Leather Car Keychain
This key chain make of Zinc Alloy and Leather has built in quick release keyring clip make it very easy to add or remove keys and to put on or take off your belt loop.
Detachable Design Key Chain
Premium detachable design allows you to separate keys if needed with 4 extra key rings, a good keychain to hook your car keys and home keys and this works perfectly.
Multitool Key Chain
This is an everyday work item as you require multiple keys during the day and you can DIY your keys on the two part keychain. Also you can use the two parts as individual or both together.
Department : Unisex Adult
Date First Available : September 29, 2022
ASIN : B0BGS9GLH2
Made in China
Buckle closure
Hand Wash
Upgrade Material: This key chain make of Zinc Alloy and Leather has built in quick release keyring clip make it very easy to add or remove keys and to put on or take off your belt loop. Also you can use the two parts as individual or both together.
Detachable Designed: Premium detachable design allows you to separate keys if needed with 4 extra key rings, a good keychain to hook your car keys and home keys and this works perfectly.
Multitool Key Chain: This is an everyday work item as you require multiple keys during the day and you can DIY your keys on the two part keychain.
