Price: $9.99 - $15.99
(as of Mar 27, 2025 12:45:23 UTC – Details)
Multitool Key Chain Clip
This is an everyday work item as you require multiple keys during the day and over the years have tore up multiple belt loops from regular clips.
Lightweight But Convenient Key Rings
One of the lightest hardness key chain (2.75×0.98×0.2 in, 1.2oz). It also provides a slight advantage by allowing for a key ring to slip down to itโs smartly designed โpocketโ.
Upgrade Zinc Alloy Material Keychain
This key chain make of Zinc Alloy has built in quick release make it very easy to add or remove keys and to put on or take off your belt loop.
Department โ : โ womens
Date First Available โ : โ January 28, 2022
ASIN โ : โ B09RG5R325
Made in China
Snap Hook closure
Hand Wash Only
Upgrade Zinc Alloy Material: This key chain make of Zinc Alloy has built in quick release make it very easy to add or remove keys and to put on or take off your belt loop.
Double Latch Designed: Premium detachable design allows you to separate keys if needed with 4 extra key rings, a good keychain to hook your car keys and home keys and this works perfectly.
Multitool Key Chain: This is an everyday work item as you require multiple keys during the day and over the years have tore up multiple belt loops from regular clips.
