Price: $69.99
(as of Jan 13, 2025 05:30:28 UTC – Details)
Special thick hard ware can shield vehicle circuit interface. Silicone case to prevent weathering corrosionUpgraded Backup System Loaded with Advanced Features – Complete backing camera with clear monitor and all the essential accessories for easy DIY plug & play installation.
With 18 infrared lights, the camera will provide HD night vision images for you.
Parking Lines Assistance will make your parking safer and faster.If you don’t need it, you can turn off it via Menu or disconnect the green wire.
7-inch LCD screen provides colored and vivid images with more detailsThe bright color display technology restores the colors of the real world
choose ASIN B0B924Z2NJ to gect second cameraWhen you want to see another camera, just press the “V1/2” button.
The camera uses a unique potting process to achieve an amazing level of waterproofing.No need worry about driving in the rain or bad weather.
The Multiplexer Controls The Camera View Between a Mirror Image And a Normal Image. Image can also be inverted. Choose freely in settings.
The New Upgraded One Has a Perfect Viewing Angle Design of 170°, Further Improving The Vision with Better View-Scale.
The lens of the camera can be adjusted up and down, allowing you to view from different angles.
It contains two cables for two cameras, you can ask us for the more cables if you need.If you want to view the instructions before purchasing, please reach us, we are willing to provide you.
7-inch Screen Car Rear view Monitor: 2-channel video input, high resolution image, full color display and low power consumption, adjustable brightness, contrast and color. Image can be rotated horizontally and vertically for mirror or normal viewing
IP68 Waterproof RV Backup Camera (No Guide Lines): Hard Metal Cased Camera, waterproof and Mud proof. 18 IR LEDs for Night Vision + 120° horizontal wide view angle + 180°vertical adjustable angle to view the blind spots. You can get it work Full Time when connect to constant power source
Extended Aviation 4 Pins Connector Cord: Strong anti-interference, more close connection, easy to install. Special thick hardwire can shield vehicle’s circuit interference better than normal AV cable
Wide Comatability: Voltage Range From 12-24V DC Power to Accomodate a Wide Variety of Large Vehicle as Truck, Bus, RV, Tractor, Car and ect.
