HD 1080P Backup Camera System Kit,9” IPS Monitor with Record Function Infrared Night Vision DVR Monitor +4 Split Screen Waterproof Reverse/Side View Camera for RV Truck/Semi Box Truck/Trailer(12-24V)
Price: $292.99
(as of Apr 17, 2025 17:45:22 UTC – Details)
【360° View】With 4 cameras as front/rear/side camera, this rv backup camera system can not only provide rear view when you are parking or reversing but also provide 360° view when you are driving.
【DVR Record Funtion】With built-in DVR recording function,This 9 inch monitor Support 4 cameras to record live at the same time, and also support to view playback, so that all details have nowhere to hide.
【IP66 Waterproof and Super IR Night Vision】Using full-sealed and glue-filling tech, those side view/front view/rear view camera can work great on all weathers. With infrared LED lights, those backup cameras can provide you bright & clean view at night.
【Easy to Install】This backup camera system powered by fuse box, connected the red to ACC(12-24V), the black connect the Metal (Ground), the green connect the reverse gear circuit as a trigger power, monitor and backup camera will automatically turn ON/OFF when the vehicle is ON/OFF, different channels can set by the button on monitor.If your wiring is correct, the screen will actively display the corresponding picture when you turn left, right or reverse.
【Customer Service】All product will be offered a 30 days’ free refund.12 months factory warranty and brand new replacement post within 24 hours If any defective item when receive .We provide Lifetime Support and 24 Hours Customer Service and Technical Support.
