Price: $84.99
(as of Jan 31, 2025 13:30:28 UTC – Details)
This RV Backup Camera with 7 Inch Monitor
This RV backup camera system is a wired backup camera system. No need to worry about signal loss and signal interference
Wide Viewing Angle
The reverse camera provides 130-degree perfect golden viewing angle
Image Flid
With the image flip function, you can switch the screen to rear view/front view
IP68 Waterproof Camera
The camera is made of IP68 Waterproof and works perfectly even on rainy and snowy
Super Night Vision
Pretty Clear Video, 6 lens glass, and 18 IR LED lights
How to install the rv camera ?
【Stable Signal Transmission】The wired backup camera adopts wired transmission, compared with wireless backup camera transmission, the signal is more stable and reliable. We equip you with a very strong cable, so you will not easily lose the signal.
【Dual-Channel Camera System】The backup camera with monitor 2-channel video input, high image resolution, full color display with low power consumption, adjustable brightness, contrast and color. And the installation of two channels back up camera is as easy and efficient as one.
【DIY Parking Grid Lines & Image Flip】The backup camera with monitor allows you to adjust the parking grid lines, you can adjust the guidelines at will according to your own needs, as well as the image can be flipped according to your own needs, to ensure that you back up more easily and efficiently.
【720P HD and 130°wide viewing angle】The rv backup camera has a 7-inch 720P HD display that provides a clear and realistic image display, enabling drivers to see vehicles behind them as well as obstacles more clearly. The backup camera’s 130° field of view angle covers a wider range, reduces blind spots and improves safety.
【Reliable Customer Service】HAOKEO offers lifetime technical support, a 2-year replacement warranty and a free 30-day return and refund policy. Contact us if you have any questions and we will help you solve your problem.
