Hank Crank Weather Radio, NOAA Weather Radio AM FM Radio, Waterproof Emergency Radio with LED Flashlight & Cell Phone Charger & SOS Alarm,Built-in 2000mAh Rechargeable Battery
Price: $25.99 - $20.87
(as of – Details)
LED FLASHLIGHT:NOAA weather radio has four lighting modes: the near beam mode, the high beam mode (the longest lighting range can reach 10m), the high beam & proximal mode and the flash light mode (press the SOS button, the SOS alarm will sound, the LED light flashs). You can choose the right lighting mode according to the actual situation,which will meet diverse needs.
Power: When you need to charge the AM FM radio, choose the correct power supply according to the actual situation. Manual power generation and solar panel charging are suitable for the electricity required for emergency regeneration. USB charging and battery extend function is suitable for the convenient charging method during daily use. Waterproof emergency radio has a voltage stabilizer built -in, and the current of the portable radio is stable, safe and reliable when charging.
Convenience: The portable radio can be used with headphones (not contained in the packaging), which guarantees the privacy of users during use. The emergrncy wind up radio uses ABS shell and IPX 3 waterproof function, which can be used normally even extreme weather outdoors.
Practicability:When the weather radio noaa alert’s battery is fully charged, can be used more than 10h (depending on the radio power usage) or LED lighting 15-16H. A variety of charging methods, fast charging speed, sustainable power can ensure that the radio can be used for a long time. The external charging function of the radio can charge your mobile phone device, keep in touch with the outside world, and send signals in time.
