Hand Crank Radio Portable AM/FM NoAA Weather Radios Emergency Crank Flashlight Solar Panel with 2000mAh Rechargeable Battery, Type-C Cell Phone Charger & SOS Alarm for Indoor Outdoor Camping Emergency
Price: $35.99
(as of Mar 18, 2025 21:45:18 UTC – Details)
☞【Multi-function Power Way】What can we do when meet an emergency but electricity failure? The emergency flashlight radio is specially designed for giving solution. Built-in 2000 mAh rechargeable battery offers long running time with AM/FM/NOAA radio & flashlight function. It has 3 ways to generate power in case of power outages. USB charging/Solar Panel/Hand crank could supply power no matter any emergency situation you encounter, the Dynamo radio hand crank generator is enough to provide emergency power to a cell phone for a necessary call or text messages during emergency in outdoor activities. The emergency radios provide power to keep you connected with families and emergency services.
☞【Ultra Bright Light Flashlight & SOS Alarm】This emergency weather radio with an SOS alarm, great for outdoor enthusiasts. Our utility radio built-in 3 white LED light source helps you see and find stuffs you need in the dark during an emergency power outage which could work lasts 12H when fully charged. It is also equipped with an emergency SOS button, which could activate a loud alarm with light flashes. The loud and bright SOS alarm flashlight will notice and position you to increase the chance of survival.
☞【Stylish & Durable Design 】 The upgraded crank radio is very easy to use and has a simple operation. The panel is painted with metal powder, which makes the radio more durable and wear-resistant. What’s more, the shells are sprayed with rubber paint could prevent them from scratching and getting a dent. With stylish modern design, the whole body gives an appearance of delicate premium. This waterproof IPX3 emergency radio is reliable and necessary for home use and outdoor travel.
☞【Portable & Lightweight】The lightweight portable weather radio is a hassle-free tool to carry on. Keep it in your trunk, or your suitcase, or carry it by hand with the attached lanyard. It’s even small enough to fit in your pocket. This type of radio is your smart choice! Packing included: 1 x Hand Crank Radio,1 x Type-C USB Cable,1 x Lanyard, and 1 x User Manual.
