GREATONE 5000mah Emergency Radio Camping Lantern, Hand Crank Am/Fm/NOAA Weather Radio, 3 Kinds of Lighting Mode Solar Radio, Cell Phone Charger, SOS Sound and Light Alarm
Price: $29.99
(as of Mar 05, 2025 22:00:35 UTC – Details)
greatonegreatone
Greatone
It is our purpose to provide people in need with various styles of weather radio.
GREATONE weather radio
MULTIPLE WAYS TO CHARGE:This emergency radio wears a 5000mAh rechargeable battery with three charging modes: solar charging, type-c charging, and hand-cranking charging. weather radio also has a battery compartment that can hold 3 “AA” batteries (not included) as a backup power solution. So you don’t have to worry about the power of this hand-cranked light in an emergency
3 LIGHT MODES:Solar radio has 3 light modes respectively: weak light, strong light, and blinking alarm. you can switch different light modes according to the situation, so you and your loved ones can stay away from the darkness in an emergency. It is also suitable for outdoor enthusiasts and is a reliable and essential item for home use and outdoor travel
KEEP YOUR DEVICE POWERED:Hand crank radio incorporates a 5000mAh power supply and can use the hand crank to continuously generate power, the wearable USB output port can quickly charge your phone to keep sufficient power in emergencies
MULTIFUNCTIONAL EMERGENCY:Built-in USB output port can charge your portable devices, emergency radio has SOS sound and light alarm function, allowing you to seek help in an emergency. Great for outdoor camping, wilderness survival, hiking, and night riding, a perfect hurricane preparedness item
