Price: $142.98
(as of Aug 10, 2024 04:45:15 UTC – Details)
GOCOM has committed to market research, design, manufacturing and sales of communication devices for many years, providing complete solutions for our customers.
Product Dimensions : 8.03 x 1.77 x 2.36 inches; 4 Pounds
Batteries : 12 AA batteries required. (included)
Date First Available : January 11, 2021
Manufacturer : GOCOM Technology Co.,Ltb.
ASIN : B08SLMRVG4
Country of Origin : China
【SOS Emergency Botton & Flashlight】The walkie talkie comes with a red SOS button,make the walky talkies turned on and press the red SOS button for 3 seconds, red LED light will be activaed and emit SOS signal. This LED bulb uses a strong light, which is brighter than the LED light of an ordinary walkie-talkie, reaches the standard of a flashlight.
【USB Charging Walkie Talkies】Comes with 6 AA Ni-MH rechargeable batteries 1200 mAh, has high safety and long life, so you don’t need to buy the batteries again and again. The rechargeable two way radios have USB charging cable and original fast charger, more convenient to charge anytime, anywhere, such as charged by PC, car charger or power bank.
【NOAA Weather Alert】NOAA Weather Scan will automatically scan through 11 available weather (WX) band channels and locks onto the strongest weather channel to alert you of severe weather updates. US only. NOAA Weather Alert will sound an alarm indicating that there is a risk of severe weather in your area, and you will always be prepared for the unexpected. NOAA radio service may not be available in all areas.
【High power and low power】The two-way radio can be set to high or low power, with a maximum power output of 2 watts and a minimum power output of 0.5 watts. Users can choose to communicate at different power levels, with high power suitable for longer range communication and low power suitable for shorter range communication, while also helping to conserve battery life.
【22 Channels & Long Range】Long Range Two Way Radio come with 22 channels and 121 privacy codes, totaling 2,662 combinations, it’s easy to find an available channel, to help conversations privacy, you can set the particular channel for your friends and family.
【What You Can Get】4 x GOCOM G9 Adult FRS Walkie Talkies; 2 x Desktop Charger; 4 x Belt Clips; 1 x Original fast charger; 2 x Micro-USB Cable; 4 x Earpiece, 12 x AA 1200mAH NiMH Rechargeable Battery; 1 x User Manual.
