Price: $1,099.49
(as of – Details)
Goal Zero is a leader in portable power-station solar generators for a reason. We harness clean, renewable energy that can power your home in an outage and equip you with the ability to charge your phone, laptop, and more off grid. The Yeti 3000X with the Boulder 200 Briefcase flexible solar-panel duo is a solar generator that has your back when the power goes out and you’re left in the dark. The included 30-foot extension cable and solar combiner set you up for success when you’re combining your solar-panel kit.
The Yeti 3000X solar-powered generator weighs 69.78 lbs. and measures 15.25″ x 10.23″ x 13.6″. With the Boulder 200 Briefcase solar-panel portable pair, it can charge in a minimum of 9 hours. Each Boulder 200 Briefcase portable solar panel weighs 42 lbs. and measures 40″ x 26.75″ x 3.5″ folded and 40″ x 53.5″ x 1.75″ unfolded. With the 30-foot extension cable and solar combiner, which is a 4x high-power-port to high-power-port combiner, you can set up your 200-watt solar-panel kit in a way that works best for you.
From sunrise to sunset, your Yeti 3000X + Boulder 200 Briefcase 200-watt solar-panel pair ensures your coffee maker, fridge, and other large appliances and devices stay powered up and charged. With this solar generator on your side, you’re free to make the most of any situation. Whether your home is your RV, a cabin in the woods, or a bungalow in the suburbs, the Yeti 3000X and Boulder 200 Briefcase pair have your back when power is lacking.
Goal Zero was born from one belief: lack of resources should never limit human potential. We started by using solar-powered products to help people lift themselves out of difficult circumstances. From there, we pioneered a category of portable, sustainable power designed to improve the human experience. We help you prepare for the unexpected so you can go farther, stay longer, and connect with those who matter the most. Power anything, anywhere with Goal Zero.
HIGH-ENERGY SOLUTION: This solar generator matches 3,032 Wh with unlimited solar power from 2 Boulder 200 Briefcase solar panels. With a lithium-ion battery at its core, the Goal Zero Yeti 3000X equips you with safe, clean, portable power for camping, tailgating, or emergency home backup.
EXPERIENCE UNLIMITED POWER: Charge the Yeti 3000X from the sun with your Boulder 200 Briefcase solar panels, and keep it topped off with a wall outlet when you’re at home. The integrated MPPT charge controller ensures you’re getting the most efficient solar charge possible.
HARNESS THE POWER OF THE SUN: Hook up the Yeti 3000X to your 2 Boulder 200 Briefcase portable solar panels to charge your larger devices and power your fridge. Off grid or in your backyard, the Yeti 3000X will stay charged from the sun with your Boulder 200 Briefcase solar-panel pair.
WHY GOAL ZERO: Our foundation rests on our efforts to present a new way forward in portable power use at home and off-grid, but also in our humanitarian roots and legacy. Since 2009, we have donated our time and products to disadvantaged communities, and our efforts have impacted over 100,000 lives. Our products are engineered with precision here in the U.S. with a real-life use case in mind.
