Price: $479.99
(as of Apr 15, 2025 11:30:29 UTC – Details)
The Cel-Fi G+ RV is the most powerful multi-user cell phone signal booster for boats and marine vehicles with +70dB gain! Compatible 4G LTE & 3G Networks: AT&T, Verizon 4G, T-Mobile, Sprint and US Cellular. It features the IntelliBoost technology which allows it to automatically adjust to the fast changing cellular network conditions as you move.
The kit was designed by Signal Unlimited, a Cel-Fi Authorized Partner, and includes everything you need for a simple installation.
The Cel-Fi Difference:
Multi-User
Multi-User Mobile Coverage.
More Power
+30 dB gain (1000x) for stationary mode and +20 dB gain (100x) for mobile mode compared to the competition.
Better Monitoring
Cel-Fi WAVE App allows for remote monitoring, carrier/mode switching, and easy installation.
Cel-GO+ RV Complete Kit
The Cel-Fi GO+ RV is a three-part system featuring an external antenna, +70 dB amplifier, and an interior wideband patch server antenna for complete vehicle coverage for multiple users.
1 x Cel-Fi GO+
1 x External Turcker Antenna
1 x Interior Wideband Patch Server Antenna
1 x Power Supply
1 x Manual
The Cel-Fi GO+ RV is a great buy for anyone looking to do away with poor signal problems while on the go. Installation is simple, and hard-mounting the trucker antenna only takes a few minutes.
Cel-Fi WAVE App for Switching Carriers
Cel-Fi WAVE is the software application and cloud-based portal solution used for registerin, setting-up, optomizing, remotely monitoring, and updating the Cel-Fi hardware. Available in iOS, Android, Tencent, PCm and Mac devices.
The Cel-Fi GO+ Installation
01. Install Trucker Antenna
Mount antenna on side of window. Make sure you consider the entire system and required cable lengths.
02. Install Server Antenna
Install in the cab where coverage is needed.
03. Mount & Connect Cel-Fi GO+
Find a good mounting location in your vehicle. Make sure it has airflow and is within reach od the 12V power supply on your RV. Connect all cables and power on.
04. Se up System with Cel-Fi WAVE
Use the Cel-Fi WAVE app on a smartphone with the Bluetooth enabled to connect to the Cel-Fi GO+ system and manage the boost settings or switch to desired carrier.
KEEP IN TOUCH WHILE IN MOVEMENT: Vanishing bars and dropped calls just aren’t an option in today’s constantly-connected world, so let the Cel-Fi GO RV cell phone signal booster pick you up when signals get low. Banish choppy calls, unsent texts, sluggish streaming, and the dreaded GPS “re-routing” loop with Cel-Fi GO RV superior signal amplification. Get the Cel-Fi GO RV cellular signal booster and never stop to ask for directions again.
THE BEST BOOST: The Cel-Fi GO RV cellular signal booster has everything you need to stay connected on the go. The smart signal booster mobile applications is the premium solution for multi-band on-the-road connectivity. Compatible with all smart devices on all major US carriers the Cel-Fi GO RV signal booster amplifies your specific signal without interference.
EASY INSTALL: Enhance your existing 3G and 4G LTE service with Cel-Fi GO RV mobile phone booster in 5 easy steps. (1) Install the donor antenna, (2) then server antenna, (3) mount Cel-Fi GO, (4) connect donor and server antennas to the Cel-Fi unit, then (5) connect donor and server antennas to the Cel-Fi GO RV unit.
THE CEL-FI SOLUTION: The Cel-Fi GO RV cellular signal booster gets the best possible signal for YOU because it works exclusively with your carrier. The Cel-Fi GO RV singles out your carrier’s bands for the biggest gain and ensures that your signal isn’t held up in the traffic of other carriers. If you switch providers, you can update your preferences in a flash with the Cel-Fi WAVE app.
FCC APPROVED – With 100 dB max gain in stationary mode and 65 dB max gain in mobile mode, the Cel-Fi GO meets all FCC requirements and will not harm the carrier network. With 22dBm uplink power and 16 dBm downlink power, this carrier-grade solution will give up to 1000x stronger boost than other boosters, making it the most powerful solution on the market today.
