GENMAX Portable Inverter Generator,3200W ultra-quiet gas engine & RV Ready, EPA Compliant, Eco-Mode Feature, Ultra Lightweight for Backup Home Use & Camping (GM-3200i)
Price: $599.99 - $389.99
(as of Feb 08, 2025 07:45:19 UTC – Details)
【Super Quiet, Fuel Saving】Fully enclosed design dramatically reduces noise levels. At 23 feet distance, 57 DBA with no-load, 62 DBA with 25% load, 68DBA with full load.  inverter technology provides clean, stable power for sensitive electronics, tools and appliances,Capable of running for a long time for 8 hours in the case of 1 gallon of fuel, with “economy mode” for maximum fuel efficiency.
【Ultra-Lightweight, Extensive use】At only 47.3 pounds, this inverter is one of the lightest 3000-watt inverters in the industry and has the best power-to-weight ratio. It can operate a wide variety of appliances,Compact and lightweight makes transportation easy with built-in handle.
【Strong panel with Parallel function】 LED indicators alert you when unit is low on oil, overloaded or ready-to-use. USB ports to charge mobile devices. 120v 20A duplex and 120v 30A Covered outlets provide added protection from the environment. Parallel ready to connect two GM3200i inverter generator for twice the power. (parallel kit sold separately).
【GENMAX Support】Includes 1-year warranty with FREE lifetime technical support from experts.
