Price: $999.99
(as of Apr 18, 2025 05:15:18 UTC – Details)
This Bundle Contains: 1 Garmin Fenix 7X Solar Edition, Slate Gray with Black Band + 1 Signature Series Watch Stand with Charging Cable + 1 Signature Series Microfiber Cloth
Meet any athletic or outdoor challenge with the rugged Fenix 7X Solar multisport GPS watch. Its Power Glass solar charging lens uses the sun’s energy to extend battery life – powering advanced training features, sports apps, health and wellness monitoring sensors and more. Updated, ultratough athletic design features a large 1.4″ solar charged display and 51 mm case. The watch is tested to U.S. military standards for thermal, shock and water resistance. Traditional button controls that work in any environment are matched with a responsive new touchscreen interface for quick access to selections and functions. Fit the watch’s look to your lifestyle with a stylish stainless steel bezel. Use preloaded activity profiles for trail running, swimming, running, biking, hiking, rowing, skiing, golfing, surfing, indoor climbing and more. Stay informed when you’re in the snow. This preloaded profile helps distinguish between skiing and climbing. Track the details of every ride with mountain biking metrics plus specialized Grit and Flow measurements that rate trail difficulty and how smoothly you descend. Based on your running history and overall fitness level, this feature provides an estimate of what your pace could be for the distance you want to run. Trend data shows how your training is having an impact over time.
Signature Series Extra Soft Microfiber Lens Cloth for Screens
Our Signature Series Black Camo Cloth is made from suede-like microfiber lens cloth and is scratch free and streak free.
Signature Series High Quality Aluminum Alloy Watch Stand with Charging Cable – Compatible with Garmin Fenix 7 Series
Product Dimensions : 2.01 x 2.01 x 0.59 inches
Item model number : 010-02541-00-Charger-Cloth
Batteries : 1 Lithium Ion batteries required. (included)
Date First Available : April 26, 2022
Manufacturer : Certified Brands
ASIN : B09YYZ85F3
Country of Origin : Taiwan
Updated, ultratough athletic design features a large 1.4” solar charged display and 51 mm case. The watch is tested to U.S. military standards for thermal, shock and water resistance. Traditional button controls that work in any environment are matched with a responsive new touchscreen interface for quick access to selections and functions.
Use preloaded activity profiles for trail running, swimming, running, biking, hiking, rowing, skiing, golfing, surfing, indoor climbing and more. For training guidance that takes you and your fitness level into account, get daily run and ride recommendations based on your current training load and training status. Use this data to track and manage your exertion — and help avoid overexerting at the start of your run or bike.
Do more. Charge less. Solar charging yields up to 37 days of battery life in smartwatch mode. Get up to 28 days of battery life in smartwatch mode with an additional 9 days when solar charging, and up to 89 hours in GPS mode with an additional 33 hours when solar charging.
Access multiple global navigation satellite systems (GPS, GLONASS and Galileo) to track in more challenging environments than GPS alone. Navigate your next trail with ABC sensors, including an altimeter for elevation data, barometer to monitor weather and 3-axis electronic compass.
