Price: $17.99
(as of Apr 13, 2025 14:30:27 UTC – Details)
Futlidys 2 Pack Mini Torch Lighter Butane Refillable, Double Flame Butane Lighter with Visible Window, Adjustable Jet Lighter, Great Gifts for Men and Women, Without Gas (Blue)
【ULTRA-THIN BUTANE LIGHTER】- Upgrade ultra-thin design, thickness as low as 0.47 inches, feel comfortable. Easy to carry, it can perfectly appear in your wallet, jacket pocket and jeans pocket.
【ADJUSTABLE TORCH LIGHTER】- The flame size can be easily adjusted using the gadget we have provided.The double jet flame is strong enough to burn through the candle jar, and you will have more uses. You can use it to light candles, wood, and burn rope ends and more.
【REFILLABLE & VISIBLE WINDOW】- Butane lighter with fuel level window helps check and refill butane in time. Use regular butane gas and fuel filling. Invert gas canister and insert the gas canister tip into the FILL VALVE. Push it 3-5 times and each time shall last for 3-5 seconds. Stop filling once the gas begins to overflow, it’s full.(Gas Not Included).
【WINDPROOF & DURABLE】- Upgraded double jet flame lighter can work normally both indoors and outdoors, using high-quality materials (zinc alloy + Heat-resistant ceramics), and undergoing 10 process quality inspections before leaving the factory to ensure safety and durability.
