Yakry RV Backup Camera Plug and Play – No Delays 7 Inch HD 1080P Rear View Camera with IR Night Vision 2 Channels – Waterproof Reverse Camera for Truck Trailer Camper Tractor Y14
Price: $89.99 - $69.99
(as of Aug 26, 2024 22:15:12 UTC – Details)
backup camera for carbackup camera for car
1080P backup camera1080P backup camera
rv backup camerarv backup camera
backup camera with monitorbackup camera with monitor
waterproof backup camerawaterproof backup camera backup camera for rvbackup camera for rv back up camera system for rvback up camera system for rv reverse camera for truckreverse camera for truck
rv rear view camera system rv camera system trailer backup camera back up camera kit for truck rv backup camera wireless with monitor
1 Wide Compatibility 2 Eco- PVC 66ft Cable 3 Flip Image&Guideline 4 Simple Installation 5 Plug and Play
backup camera for busbackup camera for bus
Product Dimensions ‏ : ‎ 29 x 21 x 8 inches; 3.59 Pounds
Item model number ‏ : ‎ 8542135292
Date First Available ‏ : ‎ July 11, 2018
Manufacturer ‏ : ‎ iStrong
ASIN ‏ : ‎ B07DC4DM3N
Country of Origin ‏ : ‎ China
►【Easy Installation in 8 Mins】The waterproof camera and HD monitor are powered by one power supply, No need to power the camera and monitor separately, just connect the monitor to a cigarette lighter adapter/Acc/fuse etc, then wire the camera and monitor. Plug and Play – Much less installation effort than wireless rear camera systems.
►【Wired Back up Camera, Stable Signal Transmission】The wired reversing camera kit has more stable transmission and will not lose signal at any time. If your wireless backup camera is always intermittent and delayed, a wired camera is a reliable companion for every drive. The rv backup camera connects directly to the monitor via a 66ft cable and is widely used on trailer, truck, tractor, bus, rv, van, suv and more.
►【Clear Night Vision & 150° Non-fisheye distortion camera】True IR night vision greatly enhances the image, and the back up camera works even with minimal light around, allowing you to identify objects in the dark. 150 Degree Wide Viewing Angle – Non-fisheye distortion camera, great for lane changing and nighttime backing up and parking in narrow alleys.
►【7 inch IPS HD Monitor & Anti-Glare Sunshade】The 7″ IPS display offers clearer and more vibrant color images, along with a wider viewing angle that maintains image consistency from various directions. Compare other screens, it reduces glare and flicker during long drives, making it easier on the eyes. Additionally, the backup camera for truck includes a sunshade for improved visibility in strong sunlight.
►【”Real Neck Saver” with Parking Guidelines and Image Flip】Reliable parking lines and image flip for fast and perfect reversing without having to turn around all the time, no more neck pain. Even if you sometimes have trouble figuring out the steering, just switch to the “mirror” view on the monitor, making you at ease when reversing.
►【2nd Vehicle Backup Camera can be Added & Rugged cable】The 7 Inch Monitor has capability to monitor two video inputs V1/V2, one license plate camera or standard camera can be added to the system. If you’re tired of easily damaged cables, Y14 is your best bet. The newly upgraded cable features environmentally friendly PVC material, a dual-layer shielding structure, and pure copper interfaces. It ensures reliable signal transmission and reduces the risk of damage during bending or moving.
►【3-Year Technical Support & Quality Warranty】Yakry provides Lifetime Technical Support, 3-Year Replacement Service, and 30-Day Money-Back Guarantee for each back up camera systems for truck, please contact us if you have any questions.
