Price: $89.99
(as of Sep 10, 2024 19:30:17 UTC – Details)
Note: This wireless camera is not a battery camera. It needs to connect with power.
How to know if the camera is working?
Cover the camera’s light sensor with your hands. If it light up the infrared light, it means that the camera is powered on.
If not, it means that the camera has not been powered on. check the wiring or use another power source or power cord to test.
Why can’t I get this camera to pair?
1. System version is not correct, if you are not sure please get in touch with us to confirm.
2. The pairing procedure is not correct, disconnect the camera and wait for the pairing countdown to appear before connecting it.
What systems is the camera suitable for?
This camera is suitable for ZEROXCLUB BW101SL/BW102SL/BW103SL/BW104SL and AHD versions of HW02/SW01/SW02/B3C/B4C/B701/BW702/B904.
What about problems with the pairing process?
Please get in touch with us in time.
Suitable for the system ZEROXCLUB BW101SL/BW102SL/BW103SL/BW104SL and AHD versions of HW02/SW01/SW02/B3C/B4C/B701/BW702/B904. Model BCT01 Waterproof rating IP69k Dimensions 3 1/10” wide * 2 18/25” tall * 3” thick inches Antenna Size 6 inches Night Vision IR Night Vision Power Supply DC 12V ~24V Frequency Band 2.4G Power cord length 9.8ft Connector DC Connector
ZEROXCLUB Single camera
4.8 out of 5 stars
12
3.8 out of 5 stars
34
5.0 out of 5 stars
1
$89.99$89.99
$89.99$89.99
$69.99$69.99
$79.99$79.99
$79.99$79.99
Wireless or Wired
Wireless
Wireless
Wireless
Wired
Wired
BW101/BW102/BW103/BW104…
2023 Version W01/WX02
BY701A/BY104A/BY904A/BY702A…
Waterproof
IR Night Vision
Connector
DC
DC
DC
4-pin
4-pin
Camera
Side View
Rear View
Rear View
Rear View
Side View
【Applicable】Wireless side view camera is compatible for ZEROXCLUB BW101SL/BW102SL/BW103SL/BW104SL backup camera system. For HW01/HW02/SW01/SW02/B3C/B701/BW702 system owned customers, please contact the seller to ask if this camera is compatible with your system before purchasing this camera.
【Signal distance】4rd generation signal technology, 130 feet without delay
【Waterproof】IP69 waterproof, Ambient temperature between -20 degrees and 65 degree
【Night vision】24 auto infrared lights that automatically illuminate in the dark
【Package Contents】a camera, a 10ft cable, an antenna and a few screw
