Wireless RV Backup Camera for Trailer Truck Camper Digital Rear Side View Cameras & HD 1080P 4 Splits 7″ DVR Screen with Adapter for Furrion Pre-Wired IP69 Waterproof Night Vision 170° Wide View Angle
Price: $369.99
(as of Aug 16, 2024 08:45:23 UTC – Details)
Wireless Backup Camera System with 4 Splits Screen
Wireless Backup Camera System with 4 Splits ScreenWireless Backup Camera System with 4 Splits Screen
The quad-split screen backup camera offers a comprehensive view from all four cameras at the same time. It reduces blind spots, enhances parking safety, and helps control the reversing process more effectively. In short, it makes the backup camera more comprehensive, safe, and convenient.
1080p wirelss backup camera system for Cars Truck Pickup Trailer Camper Bus RV 5th Wheel.
1080p wirelss backup camera system for Cars Truck Pickup Trailer Camper Bus RV 5th Wheel.1080p wirelss backup camera system for Cars Truck Pickup Trailer Camper Bus RV 5th Wheel.
This backup camera features a 7-inch large screen with 1080p HD resolution for clear images. It uses wireless transmission technology for a stable signal without wires. It has a recording function and touch buttons for easy operation. The quad-split display shows images from four cameras simultaneously, offering a comprehensive view.
Wireless Backup Camera easy to install
4 splts screen wireless backup camera4 splts screen wireless backup camera
This backup camera is easy to install with separate power connections for the camera and monitor. No wiring on the vehicle body is needed, making the installation process simple and convenient. Just connect the camera and monitor to the power source. Even without professional skills, the installation is hassle-free. In summary, it is easy to install without complex wiring on the vehicle body, needing only power connections for the camera and monitor.
7 inch Wireless backup camera with strong stable signal
wireless backup camera easy to installwireless backup camera easy to install
Wireless backup cameras have a strong signal and long signal distance. This ensures stable transmission of images and audio, eliminating interference and signal loss. The signal can reach up to 330ft, allowing real-time observation of the rear over a larger range, enhancing driving safety. They also have excellent signal penetration capabilities, making them suitable for complex environments with obstacles. This makes wireless backup cameras an ideal tool for better understanding surroundings and providing a convenient and safe reversing experience.
170° wide angle douxury backup camera170° wide angle douxury backup camera
douxury mirror backup cameradouxury mirror backup camera
douxury backup cameradouxury backup camera
Super Night Vision
This camera has a 170-degree wide-angle lens that offers a broader perspective for better observation and increased driving safety.
Mirror and Flip
This backup camera can horizontally flip the image displayed on the screen to match the actual situation.
IP69 Waterproof Level
IP69 waterproof ensure excellent performance in extreme weather, can withstand extreme temperatures from -4℉~149, offering reliable visual assistance for reversing.
douxury backup camera with super night visiondouxury backup camera with super night vision
douxury backup camera with adjustable parking assist linedouxury backup camera with adjustable parking assist line
douxury backup camera 3 ways to install the monitor3 installation waysdouxury backup camera 3 ways to install the monitor3 installation ways
Super Night Vision
This backup camera is equipped with 18 infrared lights for excellent night vision. It provides clear black and white images in dark or low light conditions, ensuring a reliable visual aid when backing up at night.
Parking Assist Line
This backup camera has adjustable stop lines that can be adjusted as needed. It will give you accurate directions to help you reverse and park smoothly.
3 Ways to Install the Monitor
3.9 out of 5 stars
63
298
841
4.3 out of 5 stars
513
4.1 out of 5 stars
109
$369.99$369.99 $134.99$134.99 $139.99$139.99 $199.99$199.99 $298.99$298.99
System Type
Wireless Wireless Wireless Wireless Wireless
Screen Size
7 INCH 5 INCH 7 INCH 7 INCH 7 INCH
Resolution
1080P 1080P 1080P 1080P 1080P
Camera Waterproof Level
IP69 IP69 IP69 IP69 IP69
View Angle
170°+ 130°(Side View Cameras) 170° 170° 170° 170°+ 130°(Side View Cameras)
Cameras in Package
4 1 1 2 3
Additional cameras that can be added
0 1 3 2 1
Other Functions
Assist Line ON/OFF + Image flip Assist Line ON/OFF + Image flip Assist Line ON/OFF + Image flip Assist Line ON/OFF + Image flip Assist Line ON/OFF + Image flip
DVR Record in Loop
Upgraded Digital Backup Camera: The latest version of the digital signal wireless backup camera will send a powerful signal to the 1080p display. The signal can reach up to 825 feet in open areas and work within vehicle range up to 320 feet.
Touch Buttons & HD 1080P: Reduce the risk of key failure, rv monitors are more durable, smoother and have a longer lifespan. 1080p HD images during the day, bright and clear images at night
IP69 Waterproof: with upgraded sealing technology, rv backup camera can reach IP69 waterproof. Can withstand extreme temperatures from -32°F to 187°F. The lens does not get wet and does not fog.
DVR Recording Function: The wireless rv rear view camera has a loop recording function. You can avoid a lot of traffic scams/thefts. Compatible with RV car truck bus trailer camper semi truck and other types of vehicles.
4 Channel Monitor System: This RV backup camera system contains 1-full-screen mode, 2-split-screen mode & 4-split-screen mode. You can choose a full screen or split mode according to your needs.
Easy to Install: You just need to power on the backup camera and the monitor respectively. Wiring and installation no longer affect your camper trailer.
