Wireless Bluetooth Headset with Dual Microphone Noise Cancelling,Auriculares Bluetooth Earpiece 30 Hrs Talking Time V5.3 Bluetooth Earphones Wireless Headset for Trucker/Driving/Office
Price: $32.99
(as of Sep 01, 2024 22:15:15 UTC – Details)
11
11
12
12
13
13
14
14
15
15
16
16
17
17
18
18
Check Battery and Main Engine/Host Interface
If battery socket half-loaded into the main engine/host, there are gap between battery and main engine/host,poor contact causes power to fail, headset can’t work, please insert battery into main engine/host firmly,seamless connection.
Battery Charge
Please charge separate lithium-ion battery only, there isn’t battery in main host/engine, if you charge the main host directly will damage its sensitive component.
IPX6 Water-resistant
Aminy bluetooth earpiece Inner splash proof nano coating ensures the headphones won’t be affected by sweat or light rain. However, we do not recommend you use the headset in pouring rain,shower bath or swimming.
19-1
19-1
Touch Control Instructions
Power On/Off: Hold MFB button 2s/5s
Play/Pause: Touch once MFB button
Next Song: Touch twice MFB button
Answer/Hang up: Touch twice MFB button
Reject call: Hold MFB button 2s
Volume+: Long touch MFB button to get desired volume,Maximum and Minimum volume cycles
Activate Siri or voice assistant: Triple-touch headset MFB button
No Volume- Function,No Mute Button.
【Clear Audio Quality for Talking】 Aminy bluetooth headsets adopted bluetooth 5.3 chipse,advanced AI noise-canceling technology combines with dual mic HD microphones isolates your voice from the noise around you,provide crystal-clear conversations even in the busy work environment, Aminy bluetooth earpiece allowing you to enjoy high quality music and clear phone calls.
【Comfortable Wearing and Secure Fit】 Aminy bluetooth headphones over the ear ergonomic design with earhooks,slip it on and forget it’s there thanks to this headset’s ergonomic design. Aminy wireless headsets featuring with over ear design and soft lightweight material,only 0.5oz lightweight, provide you comfortable wearing experience for all day use.Ultimate comfort ear gels are available in 3 different sizes to provide a snug,tailored fit.
【Left and Right Ear Switching】 Aminy auriculares bluetooth headsets with microphone for work designed to fit both ears,the detachable ear hook and flip-boom arm swivels and rotates,switch left ear wearing to right ear. Detach main host from battery,then rotate 180°host,link main host and battery,adjust microphone flip-boom arm,easy operation,so the wireless headset with microphone is best choice for Trucker/Courier/Driver/Business/Office.
【Extra-Battery and Type-C Charge Port】 Bluetooth earphones come with two batteries,each battery can support 15 hours talk time and take like 1~2 hours to full recharge,allows you 200Hrs ultra-long standby. Aminy bluetooth headset for cell phones calls up to 30 hours talk time.The bluetooth earpieces needs detached for charging,you can charge your bluetooth phone headset battery with TYPE-C charging cable.
【Portable Protective Handbag】 Made of EVA hard shell and soft sponge inner,hard quality EVA material is semi-waterproof,shockproof and durable. Available storage and effectively protect wireless headphones with microphone,allows for easy portability on the go.
【Wide Range of Application】 Support dual connection,you’ll enjoy the convenience of having up to two phones connected at once.The bluetooth earpieces is compatible with ios Android cellphone/computer/pc and other bluetooth enabled devices.
