Price: $139.99
(as of Sep 10, 2024 08:00:29 UTC – Details)
About RVTXRX Wireless backup camera: A wireless connection between the camera and monitor means that with these systems, there is no need to run cabling through your vehicle. This is usually the most difficult part of rear view camera installation and cutting it out, cuts the install time in half! This wireless backup systems also come with waterproof wireless backup cameras and excellent night vision to ensure these systems provide the best quality image as well as an easy install.
Q/A
Q: How long does it take to install a wireless backup camera?
A: Installation time varies based on vehicle but a standard one camera system should take under one hour to install.
Q: What distance does the wireless transmission cover?
A: The 2.4GHz proprietary wireless communication provides a reliable digital connection with no lag between the camera and monitor. Tested for up to 80ft at high speeds and extended range of up to 328ft in open spaces
Q: Which vehicles do your wireless systems work on? Can I use the wireless systems as a backup camera for car applications?
A: This wireless backup cameras are best for trailer applications. Although they can also be used as a car backup camera, vehicles like fifth wheels, travel trailers and semi-trucks, where wired systems are difficult to install, is where wireless really shines.
Q: Do your rear camera systems get interference from other wireless devices?
A: No, our systems use 2.4G Digital wireless signal that no interference from other devices.
Q: If it’s wireless, why do we have to run a wire to the camera?
A: The connection between the camera and monitor is wireless, however, each part still needs to receive power. All you need to run wires for is to get power going to the camera.
Q: What is the power source for a wireless backup camera?
A: The camera needs just DC12V-24V of power. For this, you can tap into power for the reverse lights or the running lights which you can find at the back of every vehicle.
DIY Guidelines
· You can DIY the guide lines on the screen, you can choose anyone according to your car. If you do not need, you can also set it on the monitor.
wireless rear view camera
Wireless transmission is 328ft at open area, suitable vehiles those are < 50ft incar use.
waterproof IP69k
Camera waterproof grade is IP69K, suitable for ultimate weather, no worries camera will get water inside
System supports two cameras
System supports two cameras and more view mode options can be choosed, such as single camera view;two cameras to be viewed at same time as split view; autoview one by one displays
Screen Rotation
Camera’s view angle can be changed from menu of monitor, convenient for install camera to different position
Night Vision
Camera is excellent nightvision with the assistance of reversing lamp helps you to see clear obstacle in the back of vehicle when you reverse the car.
❆Easy & Quick Installation: DIY design, no professional required to install, 80% buyers can compete installation without 50 minutes, save at least 3 hours & a rather large fee then the wired backup camera system.
❆Stable & Long Range Signal Strength: The 2.4GHz proprietary wireless communication provides a reliable digital connection with no lag between the camera and monitor . Tested for up to 80ft at high speeds and extended range of up to 328ft in open spaces. Compatible with RVs, motorhome, trucks, semi-trailers, box trucks, shuttle buses, commuter buses, and tractors.
❆Waterproof Camera with Night Vision: Comes with 1 High Resolution (720×480) IP69K waterproof camera with infrared night vision, live streaming, intelligent IR cut filters and wide viewing angle of 120°.
❆Multi function & 2 Channels– Intelligent switch comes with 5 functions including on/off guide lines,flip images mirrored/facing/horizontal flip/vertical flip, adjust the width/length/downward angle for guide lines. And the monitor with 2 video channels, which means you can add 2nd camera to this kit. Support full image and split images. This system included one camera, spare camera’s model is YW-0629 or search B09M6JCWC9.
❆With 15 Year Old Brand: We are the designer/manufacturer /seller ourselves for this wireless backup camera system. Our factory has passed ISO certification, product have passed FCC, CE, Rohs certification as well. Wireless backup camera system series is our core product, and we offer lifetime technical support for all our buyers.
