Wireless Backup Camera System with 4.3 inch split screen, IP69K Waterproof Wireless Rear View Camera with Night Vision, support add 2nd Wireless Reversing camera for Trailer, Vans, Cars, Rv, etc
Price: $139.99
(as of Sep 24, 2024 09:15:20 UTC – Details)
backup camera wirelessbackup camera wireless
Why choose YUWEI Wireless backup cameras system:
1. Stable & reliable digital wireless backup camera signal.
2. Our Wireless Camera Transmission Distance suitable for RV, TRAILER, 5th WHEEL, MOTORHOME, BUS and so on.
3. The monitor has a built-in wireless receiver module, while the camera has a built-in wireless transmitter module.
You will only need to connect two wires for camera, the system will work!
4. Monitor installation takes one minute, Installing the whole system is less than 1 hour, saving money and saving time. Enjoy the fun of DIY.
5. You will no longer worry about reversing in the next 5 years.
Easy & Quick InstallationEasy & Quick Installation
DIY design, no professional required to install, 80% buyers can compete installation without 50 minutes, save at least 3 hours & a rather large fee then the wired backup camera system
Camera InstallationCamera Installation
Camera can be easily installed to license plate without drilling holes.
night visionnight vision
16ft Night Vision Distance with 5 IR Night Vision Light
dual cameradual camera
System supports two cameras and more view mode options can be choosed, such as single camera view;two cameras to be viewed at same time as split view; autoview one by one displays
❆Easy & Quick Installation: DIY design, no professional required to install, 80% buyers can compete installation without 50 minutes, save at least 3 hours & a rather large fee then the wired backup camera system
❆Stable & Long Range Signal Strength: The 2.4GHz proprietary wireless communication provides a reliable digital connection with no lag between the camera and monitor . Tested for up to 80ft at high speeds and extended range of up to 328ft in open spaces. Compatible with RVs, semi-trailers, box trucks, shuttle buses and tractors
❆Waterproof Camera with Night Vision: Comes with 1 High Resolution (720×480) IP69K waterproof camera with infrared night vision, live streaming and wide viewing angle of 130°
❆Multi function & 2 Channels– Intelligent switch comes with 4.3 functions including on/off guide lines,flip images mirrored/facing/horizontal flip/vertical flip, adjust the width/length/downward angle for guide lines. And the monitor with 2 video channels, which means you can add 2nd camera to this kit. Support full image and split images. This system included one camera, spare camera’s model is YW-0629 or search B09M6JCWC9.
❆With 15 Year Old Brand: We are the designer/manufacturer /seller ourselves for this wireless backup camera system. Our factory has passed ISO certification, product have passed FCC, CE, Rohs certification as well. Wireless backup camera system series is our core product, and we offer lifetime technical support for all our buyers
