Price:
(as of Aug 17, 2024 13:30:32 UTC – Details)
No Wiring 100% True Wireless Backup Camera Powered by Built-in 9600mAh Battery
This newly upgraded magnetic backup camera does not require drilling or wiring and can be charged and used anytime. Its battery life is more durable than other products on the market. It adopts the most advanced chip technology, ensuring stable signal transmission. You can trust us with your safety.
Multi-function Wireless Vehicle bacup camera. Essential Tools for Work and Travel.
1 As a Monitoring 2 Easy to Install 3 Hitching Gooseneck 4 Packing List 5 Product Detail
Can this back up camera wireless be used directly after unboxing? How long can it be used with full charge?
It is recommended to charge the camera for 6 hours when using it for the first time.
It can be used for 20 hours during the day and 12 hours at night with a full charge.
Can you view the wifi backup camera in portrait mode on your phone?
You need to unlock or enable the auto-rotate function on your phone or tablet. Then, simply rotate your device and the camera screen will automatically expand to full screen
What is the purpose of this bluetooth backup camera?
You can use it for monitoring road conditions/cargoes, backing up safely, easily hanging the goose neck, and more functions waiting for you to discover.
Are you unable to connect to the MH Cam APP?
If your phone version is lower than Android 9.0 or iOS 8.0, it may not be possible to use this product, so please consider it carefully before purchasing.
(Not compatible with Google Pixel phone, Kyocera phone, Motorola phone)
Important information before purchasing.
The APP needs to have GPS enabled (iPhone has bound the WiFi API interface with GPS, but both the camera and app do not have cellular data connectivity, just a virtual signal, so there is no privacy issue, We can promise this).
Easy-to-install Wireless Backup Camera: Truly enjoy the benefits of Bluetooth and WiFi technology! This backup camera for truck requires no cable connections and transmits images to your smartphone via WiFi signal. The entire installation process takes no more than 3 minutes, and the dedicated WiFi channel allows for normal phone function usage. It is a helpful assistant for hooking up your travel trailer or camper for backing up.
USB and Solar-powered Charging: Equipped with a built-in 9600mAh battery that can be used for over 18 hours after a 6-hour charge, this solar backup camera also comes with a 3W solar panel with a conversion efficiency of up to 42.7%. As an additional power source, it can extend the camera’s working time up to 26 hours. You can choose to charge it at home or in your car, but solar charging depends on the strength of sunlight.
Magnetic Strength and Easy to Remove: The base is equipped with 6 round N52 neodymium magnets, which are 60% stronger than others, and is covered with soft rubber, which not only resists oxidation and corrosion, but also protects your car’s paintwork from scratches. You can easily install it on steel body surfaces without worrying about it coming off on bumpy roads, thus saving installation time. Great for trucks, RVs, trailers, vans, SUVs, pickups and fifth wheels
HD 1080P Quality: The V7 rv backup camera has been upgraded to the latest AHD camera system, with a built-in CCD sensor that converts analog light into digital pixels, providing better resolution (1920*1080). It is more sensitive to light, so it produces fewer particles and better image quality. With a resolution of 1080P, you can clearly see everything behind you on your phone. It is a friendly camera for novice, female, and elderly drivers
Excellent Light-sensitive Night Vision: Equipped with 16 940 infrared lights, it greatly improves the brightness of the image, with a wider wavelength coverage area that greatly improves accuracy, repeatability, and linearity, making it less susceptible to result deviations and protecting it from general external damage. With this camera, even driving at night is safe and ideal for those who frequently drive at night, monitor livestock inside horse trailers, and reverse in narrow areas
Stable Signal Without Interference: The V6 WiFi backup camera does not require any external power, so there is no problem with interference from in-car currents. It uses the latest wireless hopping technology for 2.4G wireless transmission, with a transmission distance of up to 32ft without any pressure in open spaces. If you frequently travel in busy cities, are a novice driver, or have limited mobility, this wireless camera is worth considering
Durable Camera: The magnetic backup camera housing is made with ABS+PC flame retardant and high temperature resistant material, and has a waterproof level of IP69K, making the camera more durable against physical impacts such as collisions, knocks and moisture. With a distortion-free angle of 150 degrees, 6-layer all-glass lens and f3.5 aperture, the entire image is clear and undistorted. The USB waterproof charging port and 4 battery indicators make it easy to know the remaining battery power
