Price: $149.99 - $129.98
(as of Aug 14, 2024 05:00:32 UTC – Details)
Solar Magnetic Rechargeable True Wireless Backup Camera +5″ Split Screen Monitor
With its powerful magnetic base, you can easily install the magnetic backup camera wireless wherever you need it. And you don’t have to wire it up and save you money on installation!
Truck Backup Camera Wireless 3 Mins Easy Install How to install the monitor?
Connect the monitor to cigarette lighter, push the button of the adapter to on the monitor. You can install the monitor on dashboard or windshield.
How to install the magnetic backup camera?
With strong magnetic base, V35 wireless rv backup camera can firmly adsorb on any iron surface.
1 Rechargeable Battery 2 Split Screen 3 Strong Stable Signal
1 Infrared Night Vision 2 IP69 Waterproof 3 150° Wide View 4 DIY Guide Lines 5 Image Flip
Vehicle Backup Camera System We Recommend
4.6 out of 5 stars
955
4.3 out of 5 stars
5,829
4.3 out of 5 stars
2,544
4.5 out of 5 stars
2,313
1,409
$129.98$129.98
$79.98$79.98
$82.99$82.99
$139.98$139.98
$199.98$199.98
Wireless
Monitor Size
5 Inch
5 Inch
7 Inch
7 Inch
7 Inch
Night Vision
Infrared night vision
LED night vision
Super night vision
IP69 Waterproof
DIY Guidelines
Video Channels
2 Channels
2 Channels
2 Channels
4 Channels
4 Channels
Characteristic
Magnetic/rechargeable battery
Stable digital signal
Support video recording
Applications of DoHonest V35 Wireless Rear View Camera
Suits for all Truck Pickup Car Small RV Camper Hitch Trailer SUV Minivan and etc under 36ft. V35 wireless backup camera for trucks will give you a peace mind when driving or parking.
Specifications of the Wireless Magnetic Backup Camera
Monitor Size 5 Inch Effective pixels 1920*1080 pixels Battery Capacity 9600mAH Battery Charging Time USB 5V 2A/ 6H Working Time Daytime/26H Viewing Angle 150° Signal Transmission Range Open distance:320ft, Effective distance on vehicle:36ft Waterproof Rating IP69K Smart IR-Cut Support Image Device 1/3″ CMOS Mounting Type Windshield Mount/Dashboard Mount Power Plug Cigarette lighter ON/OFF Material Black Aluminium Alloy Operation Temperature -20°C ~ 70°C,RH95%MAX Spread Spectrum FHSS Applications Suitable for small vehicles, such as Pickup truck, Car, Van, RV, Trailer, Tractor, Horse trailer, Forklift, etc. (Not for big vehicle)
Easy to install and remove: The wireless backup camera uses 6 super-strong neodymium magnets that can effectively attach to the metal surface of vehicles,without worrying about camera falling during driving. The monitor can be quickly powered by a cigarette lighter or USB cable,easily install the system in just 3 minutes,greatly saving your valuable time and cost. The solar magnetic backup camera design also makes it convenient to remove and reinstall reverse camera on another car or location.
HD 1080P Image and Super Night Vision: With more advanced CIS image sensor and continuous optical zoom technology, wireless backup camera for trucks improves picture imaging clarity by 80% than vehicle backup cameras. 16 IR LEDS and auto light sensor can provide clearer picture at night or under low light condition, effectively suppress glare, restore the truest color, reduce safety hazards, and ensure safer driving.
Battery and Solar Powered: Built in 9600mAh large capacity rechargeable battery, a single full charge (5 hours full) can be used for up to 24 hours, making it especially suitable for long-distance traveling. The wireless backup camera for trailer also comes with a 5W solar panel and a 5V-2A TYPE-C charger, both of which provide the RV backup camera system with longer battery life when the battery is low or the sun is low.
Energy-Saving and Security: When you do not use this system, you only need to turn off the power of the display. The car backup camera wireless will quickly enter the energy -saving sleep mode around 10s. You no longer need to manually turn off the rv camera power supply, which will reduce the charging frequency of trailer camera. And built-in 3 lithium batteries with over-charge, over-discharge and short-circuit protection, it has a longer battery life, safer and more durable.
Strong Stable Signal: The wireless rear view camera built-in more powerful digital signal receiver and frequency hopping technology, also has 2.4GHz WiFi transmission speed, strong anti-interference ability, stability is dramatically increased from the previous to 60%, the image picture without dropping frames and delay. The signal transmission distance of wireless trailer camera is up to 36ft for car, truck, pickup, camper, small RV, horse trailer, hitch trailer, SUV and minivan.
Durable Reverse Camera: Back up camera systems for truck integrated into a sealed design, preventing dust, rainwater from entering, thereby extending the lifespan. The camera is made of sturdy metal material with a higher durability standard of IP69K, which withstands physical impacts like collisions, tapping, and humidity with ease. Also the camera base is made of rubber material, which has better wear resistance and can more effectively protect the paint surface of your vehicle from scratches.
5 Inch Display Multiple Placement: Equipped with a powerful suction cup mount, bluetooth backup camera wireless can provide great stability for this screen,not vibrate or shake. You can place V35 wireless backup camera for rv on the windshield,or dashboard. Using IPS screen will make images are rendered with greater clarity and finesse, which maintains image consistency from various directions, making your eyes more comfortable.
Multi-function: The trailer backup camera wireless has two video channel, which allows you to add the second RV camera to reduce the blind spot in driving and make travel safer. 150°golden viewing angle of cordless backup camera provides a wider view and prevents image distortion. And brightness, contrast, and saturation of the displayed image can be customized according to your needs. It also has a parking backup assist system, making it a great gift for elderly or car enthusiasts.
