Wireless Backup Camera Solar Magnetic for Car RV Trailer Truck Camper 5th Wheels Hitch Towing No Wiring No Drilling Rechargeable Night Vision Portable Backup Camera with 5″ 1080P HD 2-Split Monitor
Price: $542.95 - $134.99
(as of Aug 19, 2024 23:00:35 UTC – Details)
With 9600mAh large capacity solar rechargeable battery Wireless solar backup cameraWireless solar backup camera
The camera is equipped with a 9600mah high-capacity solar battery; Simply press the power button to activate the camera; You can use the power cord to directly charge the camera, eliminating the need for hardwiring.
With strong magnetic base for cars truck pickup trailer camper bus rv 5th wheel Wireless magnetic backup cameraWireless magnetic backup camera
Wireless backup camera with powerful magnetic base, you can easily install the magnetic backup camera wherever you need it.
Wireless magnetic backup camera with stable signal Wireless backup camera stable signalWireless backup camera stable signal
The stable signal can reach 320ft in open area and 180ft in vehicles in practical tests.
Easy to install monitor and camera How to install the wireless backup cameraHow to install the wireless backup camera
The wireless backup camera is equipped with a magnetic base, which can install the camera easily. It is movable and can be installed on any metal surface you need.
How to install the wireless monitorHow to install the wireless monitor
There are two ways to install a monitor. The standard holder is attached to the instrument panel and the suction cup holder is fixed on the windshield.
Withstand extreme temperatures from -23°F~179°F. No water or fog. Wireless backup cameraWireless backup camera
Resistant to high temperature and still able to remain stable in extremely high temperature environments.
Has the performance of low temperature resistance and remains stable and reliable in cold environments.
Good dust-proof performance, keeping the equipment in a good state.
The IP69 waterproof reversing camera allows you not to be afraid of bad weather.
Wireless backup cameraWireless backup camera Infrared night vision
The infrared night vision sensor delivers clear images even in pitch-black conditions.
wireless backup camerawireless backup camera Parking assist line
You don’t need look back while you back up your vehicle. Parking assist line give you a smoother driving and parking.
wireless backup camerawireless backup camera 170° wide angle
Magnetic wireless backup camera with the wide lens which can provide a 170° wide vision for you, avoid blind spot. Make your driving safer and easier.
wireless backup camerawireless backup camera Mirror and flip
You can set mirror or flip mode for this wireless backup camera with magnetic.
2 Splits Wireless Backup Camera 2 split screen backup camera2 split screen backup camera
This wireless magnetic backup camera comes with only one camera, but you can also add an additional camera (Additional camera are not included).
Strong Magnetic Base: With a built-in strong magnetic base, the wireless backup camera can be mounted anywhere you need it in your vehicle. Attach and remove at will.
9600mAh Large Capacity Battery: Built-in high-capacity battery for rv camera “truly wireless” as the base, no additional power supply is required. Please use a 5v phone charger and the type C power cord to charge the backup camera.
Solar Charging Camera: The unique solar panel design easily uses sunlight to convert into electricity, providing stable and environmentally friendly charging support for the reverse camera. A full charge (lasting 8 hours) can last up to 26 hours, which is ideal for long trips.
Super Stable Signal: Using the latest digital chip, the wireless magnetic backup camera has a super strong digital signal up to 330 feet and up to 825 feet in open areas.
2-Splits Monitor: With a 5-inch monitor, the magnetic wireless backup camera system does not need to occupy your phone while driving. You can add a second RV camera to this system to reduce blind spots in driving and make the journey safer.
IP69 Waterproof: Adopting the upgraded sealing technology, this magnetic backup camera can achieve IP69 waterproof rating. It can withstand extreme temperatures from -32° F to 187° F. The lens does not get wet and does not fog.
